I appear to have one (the one closest to carb but missing the other (outer spring) - anyone know of a suitable replacement/part number or sizing/Dorman equivalent? BJ's and Team GW do not list these, thanks
Missing Throttle Spring
Previously 1987 GWTags: None
HELP! is a Dorman brand.
I'd get the assortment and use whichever seems to work best.
https://www.dormanproducts.com/p-28324-59207.aspxTim Reese
Ace Hardware and pick your poison'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
Thanks, yes, we have a local store which is my go to for nuts/bolt and they have a huge spring selection- Anyone know the rough diameter of the outer spring, the actual spring length separate from the spring loops? My inner spring (closest to carb) is actually two doubled up light springs - is this oem? Trying to be as accurate as I can be so I do not make too many trips to the store. BIG THANKS!James
Previously 1987 GW
