Noticed recently on our 90 GW that the power steering belt appeared to be wearing thin, riding deep in the pulley groove; looking closer - it appears that the belt is out of alignment. Thinking back, it appears that attempting to fix one problem created another. A few months ago, I swapped the flat mounting plate for one with the square hole to enable belt adjustment.
The Parts Manuals show the flat mounting plate, but Ive seen a few engine bay pics of FSJs with the square hole mounting plate that allows belt adjustment. Am wondering if the mounting brackets are different when square holes are used?
Have poked around on oljeep.com & elsewhere, looking for an exploded parts diagram that shows the adjustment plate with the 1/2-in square drive hole, but so far, no dice.
Problem 1: how to adjust the belt with the flat plate? Our GW had the flat plate, with no good way to adjust belt tension, other than prying on the pump & caving in the reservoir. I noticed in @MysticRobs Build thread, that he had the adjustment plate, so I began a junkyard search for one & swapped it in - creating problem 2.
Problem 2: belt misalignment: looking at the pulleys with a straight edge & comparing the thickness of the flat plate with the adjustment plate, it appears that the difference is how far we are out of alignment - ugh.
Wondering how I get the best of both worlds?
Pump as installed now
Side view - not how thin the belt has gotten - probably has 1000 miles on it.
Flat mounting plate
Adjustment mounting plate
Adjustment mounting plate - side view
Exploded parts diagram
Flat mounting plate
