Eliminate vacuum control for heater
  • Eliminate vacuum control for heater
    Has anyone done this. I am considering simple cable control if its feasible.
    Simple, reliable, cool.
    Providence RI
    1979 Wagoneer 6" Lift, 35" tires. AMC 401.
    Maybe a cable from a CJ would work? Sure there are other models that used them too.
    Keep it Jeep
      Would need 2 cables.
      one for defrost and one for floor vents.
      could be done but vacuum is cheap/easy/works
        You can replace the vacuum actuators with cables, but why bother? It's a very simple vacuum system. As long as the few hoses are in good shape and in place, it will work.
        1969 M715 6x6
        1963 J300 Swivel frame
          Unless the vacuum switch is worn out and you are leaking vacuum through there, then a cable would be better.
            I took my switches (4WD too) apart, lapped them on a plate of glass for a uniform surface, re-assembled with a little grease. Not worried about a leak from there anymore.
            1984 GW
            360
            Comp 260H
            Harland Sharp Roller Rockers
            Wiseco -21cc Forged Pistons
            Performer Intake
            Holley SA 670
            MSD 8523
            Dakota Digital custom cluster
            Serehill headlamp harness
            NWMP aux tank
            1987 GW deceased
            ...but the parts live on
              The vacuum switching from the push buttons has some mechanical sophistication. Kinda neat how it works, if you take the controls out and look. Converting that to cable would not be straightforward. Thru '75, the CJs use a panel hanging under the dash, with cable controls. Utility Trucks/Wagons too. AFAIK there is no aftermarket source for thes, so you'd need to fab or scrounge to get one. The cable controls for the '76-up CJ are avaiable from the aftermarket, but these Jeeps embed the cables in big flat dash, and there is no panel per se.
                I tend to agree with most. The Vacuum under the dash is basic and pretty stinkin reliable. If it aint broke don't fix it. BUT, like Wiley-Moe said, if it is broke, you could fix it that way. Then again, all the vacuum parts (motors, switches, and lines) are pretty cheap and easy to replace.
                  I've been curious about this kind of thing on mine too. Mostly because thinking about the EV conversion; it would be the one thing that would need any vacuum, so if I could eliminate the vacuum setup, then I wouldn't have to run a vacuum pump, so one less thing to draw power.
                  'Course, in my case, the EV conversion may mean that I completely redo the HVac system anyway. The motor I've been looking at is water cooled though, and you can use the tiny radiator for it as a heater core...
                  I've been thinking about it too though.
                  Current Rig:
                  '71 Wagoneer (DD)
                  B350/TH400/D20
                  6-lug conversion rear
                  Previous Rig:
                  Tan '88 Grand Wagoneer
                  .030 over 401, TBI, headers
                  3" exhaust
                  31x10.5s
                  2" rear lift blocks
                  custom headliner
