I have converted my 73 to power brakes using a booster and M/C from a 77 J10 and I believe I swapped the pedal assembly (both standards) from the 77 as well. The 77 was front disc, but my 73 was manual drum/drum. I kept and will be keeping the drum brakes. I didn't upgrade any wheel cylinders, and the original junction block is still there. I bought residual valves long ago but never put them in. That was all over 15 years ago.
Well, the reman M/C I had bought has been leaking for some time and I finally got around to fixing it. I thought it might be a good time to evaluate the whole system and maybe do it right in case it's not as it should be now.
So my questions are: should I have upgraded the wheel cylinders since I went to power brakes - not simply change them but should they be different than the ones for manual setup?
I assume the disc/drum M/C is fine for a drum/drum setup, but if not, let me know.
Is leaving the original junction block there fine?
Everything works fine, the pedal has always felt a little stiff for a power setup but not bad. It stops decent and I can lock them up if I need to. Basically all I changed was the M/C, the pedal, and added a booster. Nothing else was done/changed. I've never been sure if it was done "right" though, so any thoughts are welcome.
Thanks!
Thanks!
