Hey, guys, I posted a thread a little while back asking about new radiator recommendations for the '71. I wound up going with one of the Summit clamp-in radiators for a SBC (note; if you get an LS radiator you can use a stock Skylark upper hose and run it to the passenger's side, which clears an HEI distributor much better) (rather than bolting it straight through to the support, which gives the potential of twisting the radiator). I was super happy with it; I can run my Taurus electric fan now, and it seemed to work really well.
After about a week, though, it started leaking where the tube goes into the tank. Not a huge deal, I bought some special JB Weld stuff and it was sealed up just fine. Now it's leaking again, worse this time, in the middle of the radiator somewhere.
Anybody have any ideas as to what caused this? I did an engine swap in November/December (B350 to B350), and at that point the cooling system appeared to be fine (only thing I'm unsure of is the heater core there). Then when I started driving it with this motor, the heater core was bad (didn't realize it at the time), and when that radiator that was in it went bad, I didn't get the foggy windows from the core anymore. I put in the new radiator, and the Jeep got completely filled with antifreeze smoke, so I replaced the core. Then it was fine for about a week and, well, I already explained that.
I checked for bubbles in the coolant when idling and warming up, and all that happened was the radiator overflowed (no bubbles; I added some coolant before startup), so I don't think it's a cracked head/block, or a bad head gasket. I replaced the cap with the radiator, a stock 16-lb cap. I'm not really sure what else to check; did I just get a bad cap? Did the cap work but not release enough pressure so the radiator blew? I don't want to spend hundreds of dollars every month on a radiator, but I also don't want to be leaving a trail of antifreeze everywhere. If it's anything too major I may wind up looking at a 4.0/AX15 build...put me up around 18 mpg with similar torque (and I don't need the horsepower). Should I get another radiator and run a 13-lb cap, since it doesn't really need much pressure around here anyway? Any insight/ideas would be greatly appreciated.
Update:
Today I went to leave, and within 2 miles it started blowing some steam into the cab; the new heater core has been blown out now, too. I got that exhaust fume tester thing, and there are no exhaust fumes getting into the cooling system. I did notice that when it's cold even, the coolant level in the rad goes up pretty fast, which doesn't seem right since the thermostat is completely closed and the bypass bypasses the radiator, not just the thermostat. It gets up to temp just fine, and pretty quickly, so the thermostat's not sticking...and even if it were I don't understand why there's so much pressure there at idle when it's cold. And since the heater core's out now too...it can't be radiator specific. The other engine never did this, but then I had a 160 thermostat in it and when I put the 195 in the timing cover gasket blew. So I have no idea...like I said above, if anyone has any ideas or suggestions, it would be greatly appreciated.
Update:
