Is there a way to remove the entire knuckle assembly without pulling the hub? Outer wheel bearing is destroyed and I can't get the hub assembly to budge. I've tried heat and everything without luck. Is there a way to remove the entire assembly so I can replace it all? Or do I need to look for another dana 44?
Dana 44 front hub stuck
depends 2 different spindles/bearings could be there.
d44 stuff interchanges, no real way to tell until measured.
there are big bearing/small bearing parts and it could be either one after decades of being on road.
spindle will be toast and needs match hub/bearings used.Last edited by babywag; 02-01-2022, 08:23 PM.Tony
Yikes! That sounds ugly.
I'm with babywag, expect the spindle to be toast. Grab an air chisel and a torch and start cutting things off. Hopefully you can at least save some parts (like the axle stub shaft, and any other of the small parts). Good news is it should be fairly cheap and easy to replace all that you cut off.
You could "probably" pull the U-Joint apart and remove the spindle from the ball joints but that would probably be a lot more work and not really save you any money.
Pics?79 Cherokee Chief (SOLD, goodbye old buddy) https://forums.ifsja.org/core/images/smilies/frown.png
I just had an idea... this might be easier... So see the drawing in my first post here:
http://www.ifsja.org/forums/vb/showthread.php?t=189949
If you got the actual hub off to see the bearings themselves, you can probably remove part 36 (spindle shaft) on out in one fail swoop. So, remove the caliper, remove the disc (if you can, they are cheap so if you ruin it, worry not), then you should see the nuts that hold the spindle to the knuckle and it should all come off. If your disc is seized to the hub, you could probably push the lug studs through to get the disc off.79 Cherokee Chief (SOLD, goodbye old buddy) https://forums.ifsja.org/core/images/smilies/frown.png
spindle bolts to knuckle
hub is held to rotor via lug studs
if outer bearing is stuck to spindle only way to remove as whole assembly would be taking entire knuckle off.
then likely need to do ball joints as well.
be a lot of extra work if ask me.Tony
Oh wait.... yer right. There is a cup around those nuts that hold the spindle to the knuckle. You HAVE to remove the hub to get to the nuts that hold the spindle to the knuckle. Dangit.79 Cherokee Chief (SOLD, goodbye old buddy) https://forums.ifsja.org/core/images/smilies/frown.png
How did the spindle fair?79 Cherokee Chief (SOLD, goodbye old buddy) https://forums.ifsja.org/core/images/smilies/frown.png
