how many of you have done this with success? I found the correct Durango rear wiper motor now just trying to muster the courage to do it. This is on a 1989 GW
We did it in our 89 and it was pretty simple. Making the arm was harder than mounting the motor. I just bent and cut down the durango arm to match the wag arm. Here is a pic of it mounted in the tailgate. You will need to make a bracket to stop the motor from twisting. It works perfect.
well got it all done and it works great, it was easy .... well except for the 3 times i cut and re spliced thinking it was wired wrong, i had power to the motor but wouldn't work checked fuses, relay dash switch etc. Then by accident i bumped into this little micro switch in the tail gate and it worked , so it appears with the tail gate down and the rear glass not all the way up the arm for the glass wont trigger the switch ,
I did mine five years ago (Babywag and I wrote the tutorials in the electrical section). I used it yesterday! It's one of the areas where you can really fix a mistake made by the factory.
I still haven't messed with the wiper arm -- the factory Durango arm has always been "close enough."
