Heater Blower Motor
  • Heater Blower Motor
    No power to the blower motor switch in my 1986 J20
    All fuses good, any ideas?
    There is a relay buried in circuit on '86-up could be culprit?
    oljeep.com has wiring diagrams if needed
      I found one relay under the switch in easy reach and swapped a good one I had here and no power.
      Not sure if that was the correct one it was the low hanging fruit I had easy access to
      I will look for others under the dash
        That relay looks like the correct one based on wire colors and there is no power to that relay
        Is there a fusible link wire in that circuit?
          It would be on the wiring diagram. http://oljeep.com/gw/elec/86/86_FSJ_...ramPage3-3.gif
          Looks like a thermal fuse on the resistor stack. Seems more likely. Use your multimeter to test. Don't flail, read the diagram and measure.
            It was the fuse on the thermal relay. I fixed it yesterday.
            Thank you for the replies.
