Oil pump question.
  • Oil pump question.
    Looked at a few of the oil pump rebuild threads and have a few questions. First off, I think this engine Had new bearings installed around 2002. Bearings have a date stamp. One of the piston tops was a banged up, like maybe it dropped a valve, but all cylinders were standard. Pump has a mid plate and it is worn.Do I need it and can I just clean it up using the glass and valve grinding compound. Also lots of small groves in the side of the pump gear housing. Is any amount okay, how much is to much. I will post a few pics.
    1978 Wagoneer
    Mods:
    Mid plate
    1978 Wagoneer
    Mods:
      pretty much normal wear on the pump. what a miserable design.
      on the midplate,no you don't. all that midplate does is add another spot to leak oil.
      it ranks up there with the oil line mod.
      and did somebody use silicone on those gaskets?
      Originally posted by Hankrod
        I've seen worse. whatever you do don't try to smooth it up all that does is increase the tolerances.
        The mid plate can be replaced, or don't use it if your adapter plate is in good shape.
        Hard tell how bad your cover is by a picture but if it's decent I'd rather use it than a Chinese reproduction.
          Thanks for the reply's. I will skip the mid plate, some sort of sealer was used on the gasket. I will check the clearance and ask a few more question later. Also had no oil pressure problems the year and a half I drove it.
          1978 Wagoneer
          Mods:
            never silicone. i use aerosol copper coat there if at all.
              Okay, worked on the oil pump end cover, used a piece of glass and valve lapping compound.
              1978 Wagoneer
              Mods:
                Took about an hour and a half to get it good enough for me.
                1978 Wagoneer
                Mods:
                  Before.
                  1978 Wagoneer
                  Mods:
                    After.
                    1978 Wagoneer
                    Mods:
                      Here is the plastigage. Drive gear is at .006
                      1978 Wagoneer
                      Mods:
                        Driven gear is at .004
                        1978 Wagoneer
                        Mods:
                          So to my thinking, the timing cover mating surface is not flat or the top surface where the gears sit is worn, the drive gear side is more worn than the driven gear side by .002. Also the gears to cover has some grooving, but the thickest feeler gauge I can insert is .003 on either side. So with that said, do I have A usable cover? Thanks in advance.
                          1978 Wagoneer
                          Mods:
                            So, should I lap the timing cover side to try and tighten up the clearance a little. The TSM say 2 to 8 thousands is spec, but .002 is preferred. Also I will never be able to get rid of the .002 difference between the gears.
                            1978 Wagoneer
                            Mods:
                              lap the cover till the tolerance is nil,but the gears turn freely. it will increase as it heats up. i just do mine feel. if it's off the engine,yes i would work till i can;t feel any clearance but the gears turn freely.
