Hey folks, so I've got a power steering issue that I'd like some feedback on before I start throwing money around willy-nilly.
When I picked-up my J10 ('76, N-code) I went through a fixed/upgraded a lot of the budget fixes done by the previous owner. As part of this I swapped the stock steering box for a Redhead unit from BJ's Offroad and also put in a reman pump from RockAuto. This worked ok but if you stuck the tires against something, or hit the steering stop, it would make somewhere between a chirp and a squealing sound. The belt was tight and the pulley wasn't slipping on the shaft so I figured that I must have damaged the pump during installation by not quite getting it fully bled on the first try.
So I sucked it up and bought an AGR "Super-Pump", and made sure to bleed the crap out of it before putting the wheels on the ground. Still chirped. So I finally swapped the old belt for a new belt and guess what...no chirp.
The problem is, at idle (750 RPM) or even just above, it still moans and groans and seems to struggle to move the tires around while stopped or rolling slowly. I did check the fluid level and everything looks good there.
I'm running 33" BFG AT's so that's bigger than stock but I wouldn't think they'd affect things quite so much. Is this normal for all you guys with bigger tires or is there still something amiss? When I had a Wagoneer with stock-size tires, all steering inputs were strictly one-finger so this situation seems odd to me.
