Originally posted by maybeadinosaur
Vacuum lines and Emissions
James
Previously 1987 GW
That's a good idea. Also make sure you trace your EVAP lines from the can all the way back to the gas tank.
When I was rebuilding my vacuum system (79, California emissions 360), I could not find a complete diagram anywhere. So What I did is unhook everything (and I mean EVERYTHING) and got it running smoothly to verify no leaks. Then I used all the documentation I could find to slowly hook things back together. Hook up the timing signal. Then the brake booster. then the EVAP system. Then Cruise. Then Quadratrac and heater motors. etc. I got through CA smog inspection 3 times doing this.79 Cherokee Chief (SOLD, goodbye old buddy) https://forums.ifsja.org/core/images/smilies/frown.png
Here is a video series identifying all components and explaining what each does, which someone may find helpful:
Vacuum Line Replacement, Part 1 of 3- Overview and Identification of Components
https://youtu.be/GReFi9Z59cA
Vacuum Line replacement, Part 2 of 3- Removing vacuum lines and components from a 1987 Jeep J-20
https://youtu.be/z8Lg-GsbYDk
Vacuum Line Replacement, Part 3 of 3- Rebuilding the ignition vacuum-advance harness on a 1987 J-20
https://youtu.be/oMXUsV2LzHU1987 J-20
Video projects for my J-20 on Youtube
