In doing a spring over why would a driver drop diff not work if flipped to do a passenger drop spring over?
Driver Drop Diff Flip
Well, the big issue would be that once you put it in 4wd, the tires would try to turn the wrong direction. By just flipping the axle, you move the ring gear to the opposite side of the pinion which makes the tires rotate the opposite direction, given the same input rotation.
Then there are the other issues like the caster angle being way off, the ball joints would be up-side-down, and while flipping it would raise the pinion(not to be mistaken for "high-pinion"), there would be oiling issues.1987 Grand Wagoneer,
well worn, bone stock, with 120K miles.
added a snow plow, and looking for a lift.
And leaks from the vent fitting, and we already have enough of thoseArt
ASE Master Collision Tech
And steering problems. When I was a kid I tried that with one of my first cars. A '66 Chevy Nova. It had the monoleaf and sagged bad in the back so we flipped the axle and I had 2 speeds reverse and one forwards! (194 6 cyl with Powerglide) We even drove it on the highway like that, ala "Hooper" after adjusting the steering.Jeep gauges are for amusement only. Any correlation between them and reality is purely coincidental.
Plays hob with the caster and camber too.Art
So,,,flip it. remove the knuckles and weld them onto the other side, right side up, change the gears to reverse cut gears like the newer high pinion 44s' have....now what?
J20BP Drivetrain...........
Driveshafts for all Jeeps, Constant velocity rebuilds, Replacement, Repair
775-537-7918
https://www.facebook.com/BPShafts/
Putting this back up. "Someone is gonna have to crawl under the rig"
While they gave you lots of reasons I think it wasn't a bad question. It does seem like an 'easy' solution at face value but unfortunatly it just doesn't work.82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
Originally posted by J20 projectSo,,,flip it. .............., change the gears to reverse cut gears like the newer high pinion 44s' have....now what?
J201987 Grand Wagoneer,
Will still have lubrication issues as well. Pinion bearings won't live long. The high pinions are designed to eliminate the lubrication issue.Art
