new 32 gallon tank installed...
  • new 32 gallon tank installed...
    did it for a couple of reasons....
    1. capacity/range
    2. Baffled tank, running EFI with an in tank pump, baffles are better!
    fuel gauge sender: http://www.summitracing.com/parts/cin-sn39/overview/
    32 gallon tank designed for a 91 full size blazer, picks kind of tell all and yes, those are hockey pucks used for spacers...
    she hang's an inch or two below the trailer hitch, pics make it look worse than it is actually! I like it, fired it up and no leaks!
    and yes... body work is coming.... I know it's bad lol! Eventually my rig will look like "Plasticboob"'s rig but with metallic gray instead of the red.
    1976 Cherokee 401 Quadratrac
    4" Rusty's Spring lift 31" tires
    All MSD ignition system
    EZ EFI status: Running Smooth!
    1999 Dakota Seats
    2000Tahoe Console
    Powertrax No-slip lunchbox rear locker
    Amp meter delete
    Two Wire 94Amp Alternator upgrade
    where ya buy the tank?
    Ken's:
    1966 Super Wagoneer
    5.7L 2BBl. Th700R4. NP-208. Opens. 3.31s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
    (Soon to be TBI)
      sweet, good work
      DDs
      67 KJ715 4bt AA OD 465 np205
      78 J20 Chevy 305 nv4500 np205
      Projects
      Sons Build 1980 short bed J10, j20 axles, 4bt, nv4500, np205, shortened M715 bed and fenders
      Freedom is not Free, it is paid for with Blood
        WOW
        Really NICE!!!!!!!
        80 Cherokee
        360 ci 727 with
        Comp cams 270 h
        NP208
        Edlebrock performer intake
        Holley 4180
        Msd total multi spark.
        4" rusty's springs
          I picked it up from Rockauto and the tank straps for it as well, it was around $100. Drilled some holes in the frame, placed the hockey puck spacers where they would contact the steel "bumpers" that the spare tire used to ride up against and cinched it down tight, took a little custom work but not bad.
          1999 Dakota Seats
          2000Tahoe Console
          Amp meter delete
            thinking I may take the old skid plate and maybe fab something up though this thing is just on the road most of the time, some forest trails but nothing too crazy...
            1999 Dakota Seats
            2000Tahoe Console
            Amp meter delete
              can ya post 'filler neck' pics next?
              Ken's:
              1966 Super Wagoneer
              (Soon to be TBI)
                we'll see
                it was actually the simplest part, I trimmed off the factory metal filler neck tube, used a 90 degree 1-3/4" diameter and clamped them together. Both the factory filler tube and filler tube on the tank were the same diameter, which was lucky!
                I used one of these: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
                1999 Dakota Seats
                2000Tahoe Console
                Amp meter delete
                  Originally posted by mattparliament
                  1 3/4" hose?
                  you using the dual-tube metal fill neck? don that need a 2" ID hose?
                  also, iv got the same fuel sender ready to put in my 75. hows it working for yas?
                  Ken's:
                  1966 Super Wagoneer
                  (Soon to be TBI)
                    1 3/4" hose?
                    It was just a single tube fill neck. I was all mentally prepared to redneck something together to make them work, measured one then the other and they were the same!
                    easiest part, one hose, trim ends and two hose clamps, done!
                    in the diagram right where the arrow points to "filler extension" is about where it got cut.
                    1999 Dakota Seats
                    2000Tahoe Console
                    Amp meter delete
                      fuel sender is debatable yet, haven't had much time with it. Put 7ish gallons in it, tank shows just above empty. I measured resistance at the pickup, 59 ohms, 41 at the splice to the factory wire.... I think I may be missing something and maybe I can't just splice these together...
                      1999 Dakota Seats
                      2000Tahoe Console
                      Amp meter delete
                        did ya test it before install?
                        Ken's:
                        1966 Super Wagoneer
                        (Soon to be TBI)
                          Yes I did, it was perfect
                          1999 Dakota Seats
                          2000Tahoe Console
                          Amp meter delete
                            what is the dia of the tank opening?
                            larger than jeep, smaller?
                            Ken's:
                            1966 Super Wagoneer
                            (Soon to be TBI)
                              3-1/2" if I remember correctly. Tank came with O-ring and locking ring. I used a square flat metal electrical box cover for the cap, it was a buck and just drilled what holes I needed and turned the square into a circle with the angle grinder
                              1999 Dakota Seats
                              2000Tahoe Console
                              Amp meter delete
