I am looking for advice on removing the drivers side floor pan. I can not find the spot welds on the floor pan that attach the 2 supports . I am hoping that one of the members out there that has done this can shed some light on this . Thank you .
Use an abrasive to scuff the surface, this will help with locating the welds.
Striking the floor pan near the weld locations with a hammer or other suitable tool from the underside will help as well. This process deforms the sheetmetal around the weld and makes them more noticeable. It also helps with keeping the cutting tool centered on the weld because of the depression that it makes.
FSJ Hybrid build thread: http://www.shopfloortalk.com/forums/...ad.php?t=43332
Resistance is not futile yet.
