77 Cherokee SOA and Shackle Flip
  • 77 Cherokee SOA and Shackle Flip
    So now I am starting my suspension build and I'm doing the standard SOA with 6in shackles and going to take off the rear shackle box to do a shackle flip. On the shackle flip I bought a set of Dodge 2500 rear leaf spring hangers which in my calculations will give me about 6in without the shackles.... the forward leaf spring mounts are made to be 3in drop to not offset the axle in the wheel well, but also the perches will be ground off and new installed at the angle needed for the rear drive shaft. Now with the SOA the rear leaf spring mounts are custom as well "Beefier" with 6in shackles this should be level front to rear minus the fact of maybe a shim on the front......don't know but by my math and mock up I should be close to level. Hell I might be able to stuff 42in military tires under it.. (wife might not like it but she doesn't drive it....lol) I would love feed back and thoughts. ....yes I do have high steer plans but they are custom stainless tie rods with heim joints. Thanks as alway for the support!
    Ps.
    my leaf springs are from a 2007 Dodge 2500 4wd if that helps!
    Give a man a fish he will eat for a day unless it's a really big fish but, teach him to fish and he will drink beer all day!
    1977 Jeep Cherokee wide trac 2nd owner 88,981 miles
    2006 Jeep Wrangler Unlimited
    I would think designing your rear brackets to correct pinion angle would be easier than cutting and relocating you axle perches. I am a little unsure exactly where your putting the 6" shackles.
    Remember; When it comes to tools and toys forgiveness is ALWAYS easier than permission!
      I'm a bit confused with the 6" shackle part also.
      Perhaps a simpler description or drawing would help us.
