Power steering pump - help
  • Power steering pump - help
    Guys, I need a little advice here. My PSP went bad and I need to buy a new one. It seems, according to various e-shop catalogs, that there were some changes and the break year was 78/79. My Jeep is 78, but the engine is from 81 J10 (at least I was told so). I cant contact the previous owner, who did the swap so I dont know if he kept the accesories from the old engine or swapped the whole thing in... Is there a way how to tell what pump do I need? I need to order the right one, shipping alone is over 70$.. Thank you kindly. Marty
    1978 WT Cherokee 2door, 360, T18a, Dana 20. Currently under construction.
    Difference is simply the hose fitting connections.
    Earlier are flare fittings, later is metric o-ring.
    Disconnect your high pressure line and that will tell you.
    However the fitting that the hose fitting screws into unscrews from the pump, so even if you got the wrong one you could still reuse it and wouldn't matter which one you get.
      Thank you very much sir
        Marty,
        Go with the pump from a '77 rig with a 401 if you are thinking about running tires in the 33" or larger size.
        It's the same pump as a mid 70's Caddy, slightly higher pressure which helps move big tires.
        Changing the fitting if needed is easy.
          Agree
          You can buy the pumps with both fittings & swap if needed. I know the last one I bought from Napa had the O ring one inside the box so I could use it on newer or older models.
          check this out. One bad pump also. great for big tires & hydro boost
          http://www.borgeson.com/xcart/catalo...ns-p-1716.html
          80 Cherokee
          360 ci 727 with
          Comp cams 270 h
          NP208
          Edlebrock performer intake
          Holley 4180
          Msd total multi spark.
          4" rusty's springs
            $166
            Remember; When it comes to tools and toys forgiveness is ALWAYS easier than permission!
              Yeah
              Originally posted by Mr. Goatman
              $166
              It's not a Mcparts rebuilt leaker. It's a higher volume well built unit. It makes my steering work better. If running hydroboost this beats 2 pumps. If you swap from 8 turn gear box to 4 turn with 33's this makes them turn easier.
              80 Cherokee
              360 ci 727 with
              Comp cams 270 h
              NP208
              Holley 4180
              4" rusty's springs
                Thank you all for advices. I will order something tonight
                Sometning tells me that removing that pulley will be a lot of fun
                  You can rent a pulley puller from the parts store. Or you can buy a cheapo one for about $20 or so. An air impact wrench helps with the tool use, too. If you don't have an impact, a bench vise will make life easier by holding the tool for you while you wrench away.
