Is the Dana 44 in a 77 Cherokee same Dana 44 in a Dodge Ramcharger? Aside from the steering set up?
Dana 44 Question
The knuckles out, including brakes, are different, but should be interchangeable. The diff internals are the same (same ratio carrier breaks). Degree of castor of knuckle "C" is less on the Dodge. Dodge is 5X5.5 bolt circle.
This is all assuming you're talking about an '80-'9? Ramcharger D44. <'79 had unit bearing outers that don't swap with anything.'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Short answer is yes - they are the same.Please come on over to http://fsjnetwork.com/forum and have a look.
Originally posted by Josh DThe diff internals are the same (same ratio carrier breaks).
Past that, all of my dodge D44s have had bigger diameter axle tubes than FSJs, and the vacuum disconnect Dodge D44s in the 80s did so halfway down the long tube instead of a the diff housing like everyone else.
Also, shaft lengths were different between my 85' Ram and 86 Grandwag, when, for reasons I don't want to go into, I got them mixed up.
In short, no, they're completely different except for the differential itself. What are you trying to do? Do you have another thread that explains your quandary?
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Well first off reason behind it is it is already spring over and i want to change the its over as well as it doesn't have a Jeep Z bar steering setup. Kinda a high steer stock wise.Give a man a fish he will eat for a day unless it's a really big fish but, teach him to fish and he will drink beer all day!
1977 Jeep Cherokee wide trac 2nd owner 88,981 miles
2006 Jeep Wrangler Unlimited
Originally posted by REDONEUnfortunately, this is pretty much the beginning and end of it. I'm a Mopar convert and just with my last FSJ purchase can say I've owned more FSJs than Dodge trucks. As others have mentioned, the late 70s dodges have a proprietary outer that is only worth it's weight in scrap as it has a rotor/hub assembly
Everything beyond the 'C' is dfferent, except it uses the same internal spline lockout hubs as an FSJ would use. I even used J10 tie rod and drag link, but I had to modify the knuckle arms to accept the larger Jeep TRE's. The Dodge D44 does have flat top knuckles though, so hi steer or crossover steering is a little easier.
My '71 has outboarded factory SOA, so not the same as your '77, as I welded on new spring pads.
As Redone mentioned in his post and I did as well in mine, the '79 and earlier are useless as they use a unit bearing and small bolt pattern. '92 and later use the CAD. It's the '80-'91 that can be adapted to an FSJ.
'71 J2000 Gladiator
Originally posted by CasualGourmetWell first off reason behind it is it is already spring over and i want to change the its over as well as it doesn't have a Jeep Z bar steering setup. Kinda a high steer stock wise.'71 J2000 Gladiator
Originally posted by CasualGourmetWell first off reason behind it is it is already spring over and i want to change the its over as well as it doesn't have a Jeep Z bar steering setup. Kinda a high steer stock wise.AMC V-8 FOREVER
1976 Cherokee Chief 360\4-spd(soon to be auto\ Q-trac)
1977 CJ5 "Lulu"
360\5-SPEED GRANNY\DANA300\ DANA 44s
DETROIT \POWERLOCK 4.10
37" tires, and LOTS other stuff
77 J-10 401\Q trac "Thadeus"
64 Stude Avanti 289 R2---ALIVE!
91 Dodge W350 5.9 Cummins
64 Avanti#2(R1)...Under construction
I am curious about those early 80's dodge 44 axles with vacuum disconnects?
Do they roll those without the needle bearing in the spindle on the drivers side like they do in the '83 AMC D44 axle? (It was only for 2 years, I forget if '82/83 or '83/84?)
(The passenger side does require the needle bearing.)Tourettes1978 Wagoneer
360-727-228 - MSD 6a - TFI - MSD 8.5mm - 880CCA Diehard Plat - 31x10.5x15 - LEDs in every socket
