Any reason I shouldn't be able to install a performer #3731 (EGR variant) and still use my 2150 with an adapter?
Edelbrock Performer intake question
Jeepasaurus (Wagonus Grandi quadropedus)
88 GW 360-.030 over/2150/727/229/Posi, e-pump, AC (broke), tow package, Monroe Air Shocks, TFI, CTO-Free, AIR-free, oil & tranny coolers, dried knuckle blood all over, GM 350 TBI in a box, waiting...
"You're an FSJ'r when the parts guys memorize your name, phone & credit card#."Tags: None
I would save for a 4bbl carb and do it all at the same time unless there was something wrong with my 2bbl manifold.Flint
Originally posted by fulsizjeepI would save for a 4bbl carb and do it all at the same time unless there was something wrong with my 2bbl manifold.1990 GW:
Mopar 440/727/229/D44F&R
10:1, XE250H, DIY TBI. 4.10 locked f/r, SOA/SF, high steer, all the other fancy goodies. Check out my build on FSJNETWORK.
Originally posted by cajun_ladI think you can, but why would you want to?
Is this true or a myth? That's why I'm asking.Jeepasaurus (Wagonus Grandi quadropedus)
Don't see how
A 4 barrel would offer smaller primaries & a disiplined driver could get better MPG's. There's no way a 2150 it is better in performance. Physics defy your logic. Check the cfm you'll find the 4 barrell primaries has less cfm than the 2150 & it increases when you start opening up the secondaries. The beauty of Spreadbores. As far as fuel distro how could that be possible for all intent & purposes the basic design is the same with the exception of the butterflies are smsller on the 4 bbl. Volume is less but distro is the same.The 2150 will use more gas in normal driving & the 4 barrell will have better performance in agressive driving. If you drive aggresively all the time the two barrel will not out perform the 4 barrell. Well except maybe on mileage. Clarify only when the 4 barrell is open!! All of this is assuming your going to use the correct size 4 barrell & not a 1000 Cfm unit. I'm not going to chase down the numbers here but the 2150 is a 475 CFM if I'm not mistaken & the Edlebrock 600 cfm has about 325 CFM Primaries. The 2150 if tuned perfect & the Edlebrck tuned perfect the 2150 will lose at normal driving. Open up the 4 barrell & you smoke the 2150. Putting the 2150 on a performer as discussed before is like putting a restrictor plate on the motor. I'm Really at a loss here as to why you would put the performer on & then put the 2150 back on. It will only have the same performance. Well maybe a tiny change but not worth the work. The intent of the manifold is to get the engine breathing better putting the 2150 back on is like COPD.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
But wait...there's more
Originally posted by serehillThe intent of the manifold is to get the engine breathing better putting the 2150 back on is like COPD.
But let me take this one step further: My ultimate goal is to convert to GM 350 TBI. I've got all all the parts and will proceed probably in September. With this in mind, does using the Performer intake make any sense?Jeepasaurus (Wagonus Grandi quadropedus)
Rich
Didn't mean to lecture. I was simply answering the question in depth & why. Please take it as face value. There's tons of things I don't know for sure.
Honestly I would save my money & invest it in your goals which is a cool idea. I'm working towards a similar goal I have a Hemi with a 545 sitting in the works with MSD intended to stay intact. I like it in my magnum & can't wait to see what my mileage is going to be. It's by wire technology & I don't know jack about it. The truth is the intake is for high volume air & your putting a low volume carb on it. The carb was originally designed to restrict the motor down to make in pollution compliant. Along with the air pump that adds air to the exhaust. So you wind up with a high volume intake & a low volume carburator that pretty much takes you right where you started. I simply thought you would like to know why.
What you're asking is Myth.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Originally posted by serehillDidn't mean to lecture. ....what you're asking is Myth.
But in street language, what I'm walking away with is that use of a hi performance intake with a two barrel is as useful as headers below 1000 rpm.
Tnx...Jeepasaurus (Wagonus Grandi quadropedus)
You Know
Reading Jeepstress's thread this morning did humble me & Thanks for understanding & great attitude Rich. This is the greatest forum I have ever seen ! Although this forum is diverse in answers, using a democratic format I can get the right answers. There's a million Opinions out there buddy & mine is just one of many. Since every one has different goals you just never really know what the final answer is.
One mans analogy is another mans conundrum. The street analogy works for me.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
