My yoke is slightly damaged on the rear of my NP208 transfer case. It's clearly serviceable and will hold a u-joint, but a piece sheared off, so I'm replacing it. Can someone do this without air tools?
Must replace Yoke on NP208 transfer case
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!Tags: None
I changed mine in the parking lot at Driveline Specialists in Sarasota once. Not a big deal if you don't mind spilling fluid.Flint
Ok it's on
Originally posted by fulsizjeepI changed mine in the parking lot at Driveline Specialists in Sarasota once. Not a big deal if you don't mind spilling fluid.1982 Cherokee
One more question
I checked my Haynes manual and no torque specs are listed for the yoke retaining nut. Does anyone know how much torque is specified somewhere for the NP208 transfer case yoke?1982 Cherokee
120 ft lbs IIRC.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
