The following is listed under Team Wagoneer
"Idle Speed Control Motor Relay OEM GW 1984-1990
This Is A Factory Original Fuse Block Relay. This Specific Relay Is For The Idle Speed Control Motor That Plugs Into The Carburetor Which Controls The Idle When The A/C Or Defroster Is Turned On The Raise The Idle So That The Engine Does Not Die Out Under The Load Of The A/C Compressor Kicking On. This Relay Is Commonly Overlooked Because Most Mechanics Try To Change The Adjustments To The Carburetor Which Makes Mileage Worse & Performance Flat. This Relay Is Correct & Will Fit All Jeep Grand Wagoneers & Jeep J-10 & J-20 Pick Up Trucks From 1984-1990. This Relay Just Plugs Right Into The Fuse Block In Seconds. OEM PART# 8350704"
Very well. Question is: WHAT "Speed control motor that plugs into the carburetor." ?? Never seen it, never heard of it.
