Anybody know of a Junkyard Replacement Radiator for a Wagoneer? The waggies in the junkyard don't have their radiators, mine has 2 nasty holes and I honestly don't feel like spending $300+ for a new radiator. I can get a good used one from the Junkyard for $30... So, I was wondering if any other radiator will drop into a wagoneer with minimal to none fabrication/modification...
Junkyard Replacement Rads
Originally posted by JeepModsAnybody know of a Junkyard Replacement Radiator for a Wagoneer? The waggies in the junkyard don't have their radiators, mine has 2 nasty holes and I honestly don't feel like spending $300+ for a new radiator. I can get a good used one from the Junkyard for $30... So, I was wondering if any other radiator will drop into a wagoneer with minimal to none fabrication/modification...
Zind member "halftrac" here on this board , tell Jackie I sent you, she'll hook up up w/ a wag rad I bet for fair $ I think they are close to you
Good Luck
Would you be willing to spend $200 on a new radiator?
See my sig file links for info on the radiator that I installed.Ethan Brady
Originally posted by JeepModsI'm half tempted to get that radiator... BUT, only if I can't find a good used one in the yard for $30+...I have to pinch pennies for when I have to order a driveshaft that's 44" long from center to center...
Originally posted by 710 BurnerI am surprised you can get on for $30 bucks. I think they paid me more than that for scrap because it is all brass.And then when they have the 1/2 off sales... life is good as the parts are plentiful and cheap!!! My kind of stuff. The only catch on the half off is... you have to be there when they open
I'm heading out to measure the waggy radiator and then the junyard rads... I'll let yo know what I find.
x1 on what FSJ Guy said...I got the same radiator for just under $200 shipped, and it too has cured my 401 cooling woes.90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
