bolt on exhaust setups for fsjs
  • TPICherokee
    replied
    We are in the process of having a cat-back back and cat-forward system for 80-91 Wagons. Here are the specs:
    3" mandrel bent aluminized pipe
    Stainless steel muffler
    Hi-flow catalytic convertor will be optional for those of you who need or want one.
    Leave a comment:
  • FSJ Guy
    replied
    A long time ago, I made a cat back system with the pipe pieces you buy at the parts store. Use the 45 and 90 degree bends to get over the rear axle. It actually worked pretty well.
    You could clamp it all together, but I welded it together with a stick welder, which worked fine since it didn't have to be pretty.
    Leave a comment:
  • Cecil14
    replied
    I think there are a lot of people that would probably be interested. The real problem you're going to run into is that no two FSJs seem to ever come out the same. You could certainly make a prefabbed setup, though, and people could work around that.
    aa
    Leave a comment:
  • FloridaFSJ
    replied
    It's called flexpipe and band clamps.
    Leave a comment:
  • NCOfab
    started a topic bolt on exhaust setups for fsjs
    hey people i was woundering im currently doing a couple of projects and iveknown for a while that there are no bolt on exhaust kits for fsjs would a bolt on exhaust market like this apeal to any of u if i deside to start making them
    for fsjs
