Anyone ever tried to use the woodgrain from say a PT Crusier? I have about 4 panels i need to replace and was thinking maybe i could buy one of those and cut to make it fit? Im starting next week and hoping to be done by summer with fixing some rust/headliner and woodgrain. Id order bjs kit but its the wrong color of woodgrain
Woodgrain replacement
http://www.stripeman.com
Has both "flavors" of GW woodgrain in what appear to be the original patterns.
Lou
LouJim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
'86 CJ7 Doesn't need anything(so why do I have it?)
Correction- it just needed a water pump!
Very cool, they alot of choices!
BJ's sells a precut kit for GW as well...I would link the site and a picture here but they have the whole site protected from coping with no right clicking?????WTH!
But I found a back door so here it is.....he he he http://www.bjsoffroad.com/cartgenie/prod-527.htm
Sorry his site will not allow them to be hosted on this site but if you click it you'll see them.
http://ts1.images.live.com/images/th...052bc2eff79758 <--- This one...
http://ts3.images.live.com/images/th...62123dc86cdaa6 <----this one too.Last edited by COLOFIREMAN; 04-10-2008, 09:55 PM.Jason in the Mountains
1978 J10 LB,OE 4-speed,4:10's,4BBl,and just 85K(daily driver)
1988 Grand Waggy 8" lift 35" A/T's (under construction)
1984 CJ7 12" lift 39" Iroks 1 tons
1979 Cherokee Super Chief (under construction)
1974 J-10 LB Buick 455 BB 4" lift 33" BFG tires
1973 J-4800 LB plow truck 7" lift 255/85/16 LT Truxs MT's
Lou
Granted, even if you could find some original material, or if 3M still made the stuff, it probably wouldn't match your original woodgrain because of the effects of the weather after all these years. So just be aware if you're planning on only replacing part of your wood siding - you'll probably see a difference between the old and new.
I'd buy one of their $1.00 samples before dropping the coin on the bigger pieces, just to be sure.-Frank
'63 J200 2WD
'63 J100 Panel Delivery
we do allow our pics to be posted....you just have to click on the pic to enlarge it, then right click and save.
For our woodgrain, we have a replacement sample coming soon that we will inspect. If it meets our requirements / standards, it'll get the seal of approval and be listed on the site. The original Marine Teak pattern is no longer produced by 3M, which is why we aren't currently listing it.BJ's Off-Road
ryan@bjsoffroad.com
Originally posted by billyrbwe do allow our pics to be posted....you just have to click on the pic to enlarge it, then right click and save.Last edited by COLOFIREMAN; 04-12-2008, 10:51 AM.Jason in the Mountains
