So Im in the middle of restoring my 1988 GW, I have started stripping it down to bare metal as I have found damage from the last owner taking it off road.
My issue is that they cut the rear wheel wheels out several inches to fit larger tires with the current 5in lift.
I not sure I want to buy the replacement metal parts (all 4 for front and rear of fender wheel)
I would like to add some fender flares, but I want to keep the wood paneling in the middle, wider than stock but not supper crazy.
I seen on Facebook something about using Cherokee bolt on flare but they go to high up on body and will mess up the wood center.
Anybody seen any other flare Options?
I can weld some.
Thanks .
I can weld some.
Thanks .
