Electric fuel pump
  • Electric fuel pump
    1. Can anyone recommend what brand electric fuel pump they put in their Wagoneer? Also did it come with the blocking plate?
    2. Replace melting ignition module with OE or HEI? What are the benefits?
    Tired of fuel issues, rebuilt carb and same problem! Pour gas in carb and runs great. Let it sit for hours and repeat problem.
    The Ignition mudule has been melted for years, but not sure if its a problem.
    Love my HEI but dont go cheap there are alot of cheap Dizzy that will toast your cam gears
    cheapest option will be to put the duraspark mod back on there
    87' Grand Wagoneer
    401/727/229, Currently:RUNNING
    84 J10/20 hybrid 258/727/208 Daily Driver
    80' J10 4BT/AX-15/208
    74' J10 Go Grabber Green Sold
    Originally posted by Heavy_Metal_Thunder_81
    Inferior Chevy
      Msd 6a, tfi conversion, holly fuel pump. Works great. Go ahead and drop the tank, clean it and install a new sending unit. Then you are all good.
      88 Grand Wagoneer
      360/727/NP208/dana 3.31s
      Edelbrock 2131
      Holley 600
      Hydroboost
      Hedman headers
      Dual exhaust
      MSD6A, TFI
      Digital Gauges
      Rusty's 2" Lift
      31x10.5 15LT15s
      Quote From Friend's Mom:
      "You don't rely on that vehicle do you?"
        Holly fuel pump
        Works great with my 84 360/motorcraft carb.
          And no blocking plate
          But they are about $12 at orielly.
            It's the gear that comes with all the HEI's that toast your cam gear. You can use the cheap HEI's, just use your old gear off your points dizzy.
            I used a Carter electrical pump on one of my Jeeps. I left the old manual pump in the motor.
            76 Cherokee Camo(Parts)
            76 Cherokee Camo 401/TH400/Dana300/HD44/14bolt/36s
            77 Cherokee blue 360/T18/D20/33s
            1969 AMC Javelin SST 390
            1968 AMC Javelin SST 290 (Parts)
              With a minor bit of file work a blocking plate for a BB Chev(454) will work.
                @mdcptman - how and where is your pump mounted? I bought one but it is still sitting on a shelf in the garage. Got tired head trying to find the best spot and decided to work on other stuff.
                Mike
                '87 grandwagoneer,
                MSD 6A
                229 727 dana 44 axles
                  let me know when your installing it and i'll come over with some beers and watch you work
                  '89 GW
                  360
                  TF727
                  Dana 44's (2.73)
                  Baltic Blue/Sand Interior
                  "Passing everything but Gas Stations"
                    Funny....
                    depending on year, for the early with passenger side drop, block off plate from summit or your local parts store
                    http://www.fsjnetwork.com/forum/viewtopic.php?t=11729
                    for the driver side drop, I tried the rear by the pumpkin, but it was a drag to debug when something happened, so I went up front, you can see the bracket under the steering column
                    Michel
                    74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to the next get together without a rebuilt? Status: needs a new body.
                    85 Gwag, 229 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
                    See Ouray 2013, Engine bits and Fuel and brake lines, and Body work
                      X2..I used a SB Chevy blocking plate [$9] with Holley Red pump--a great up grade. It starts sooo much faster now after sitting. Issue with HEIs and gears is because AMC used three different metal types on thier cams. If the material dont match they eat each other up. I always use the old Dissy gear on my HEIs.
                        I mounted mine on the rear crossmember tucked up next to the spare tire. I ran new line from the pump inside the passenger frame rail and up the firewall to the back of the engine. Ran the line on the passenger side of the carb and to the carb input. Got to eliminate the loop at the filter. Very clean looking. No heat sources to make it vaporlock. I used a fuel pump controller that will prime it for 3 seconds when u turn it on then stop until u start it. It runs from a tach signal so when the motor dies the fuel shuts off. I also ran that thru a relay to take the strain iff of the controll. It's awesome. I can look up the number if u want. I got it on amazon.
                        88 Grand Wagoneer
                        Edelbrock 2131
                        Holley 600
                        Hydroboost
                        Hedman headers
                        Dual exhaust
                        MSD6A, TFI
                        Digital Gauges
                        Rusty's 2" Lift
                        31x10.5 15LT15s
