Hubs .. new units from WARN, the basic lock or Free kind. [ WARN kit/Part number 20990 ]
The WARN "Lock-O-Matics" I took off? For sale if anybody wants them.
First, slide the hub body over the axle shaft, then install the large retaining lock ring on the outside of the hub. There is a groove, you just can't see it!
[IMG]
[/IMG]
[/IMG]
THEN - install the axle shaft snap ring.. it helps to push the axle outward to get at the slot. I did this with a large screwdriver against the u joint.
Then line up and start 2 screws into the hub body, push the end cover down. I added a slight amount of grease to the O ring to ensure it slid into position well and seals. Add the other bolts, snug down. Ready for Calipers!
[/IMG]
Done for the day . . .
[/IMG]
[IMG]
