been a few years since i installed one. i wasnt even gonna do it but i felt the need for a few minutes and then it was to late to stop myself.
i may regret it but i bought a body lift and new bushings.
yep
You can't have too much PB balster & you can't start spraying th eboltds too early. It's tedious but not that hard minor adjustments are require but I didn't have ave great issues. I did mine to ahieve lift & keep a low center of Gravity. Well more than total lift. I know it's not everyones cup of tea but I like it better than total lift. one of th ebest results/ side effect was more engine access. Good luck guys It's teedious & wou'll be happe you bough tnew bushing. I used an electric impact on mine to assist with losening th ebolts with great results. pusshing as hard as you can with a wrench is nt good, the impact havvers the bolts loose. It worked on mine. Take you time work the bolts. Replacing the nut plates are not fun.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
I have found with our captive nuts for the body mounts that in addition to very frequent spraying with PB that it helps to tighten them just a little.
tighten...loosen...tighten...loosen
Just enough to break the rust bond and get the penetrating oil soaked into all the threads.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
No doubt
Originally posted by TadI have found with our captive nuts for the body mounts that in addition to very frequent spraying with PB that it helps to tighten them just a little.
Best process.
I did this with my impact forward reverese forward reverse.Last edited by serehill; 03-14-2013, 10:22 AM.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
fortunatly i have a compressor here and at the barn, granted the barns 80 gallon ingersoll will me more helpfull then the 70s 20 gallon belt drive here.i man put this off till it warms up and use the neighbors post lift, since i only have a scissors lift for now.88 grand waggy with almost nothing done to it but a severe beating.
Yep
I use my electric impact because it is not as strong as my pneumatic one either could work I suppose. I just want the impacrt function not the highest power for this. I suppose there is no wrong way on this.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Originally posted by Husker77Will one of you guys make a thread and document the installation, I would really like to see how it goes.1990 Grand Wagoneer, stock (so far)
"Crate" 360 w/ 7K miles
