Wow nice job with the wheels! What rustoleum paint did you use?
My Wagoneer 1990
Andy
'81 Cherokee Laredo W/T 258/Weber 32/36 DGEV/HEI/176/208 AMC 20/Dana 44 3.31 gears
Status: Work in progress Miles: Less than 140K (as of the talk with the original/previous owner)"The Jeffrey"
Build Thread: http://www.ifsja.org/forums/vb/showthread.php?t=151814 New pics: 5/18/12
That looks black cherry to me! Did you re-clear coat the wheels? Is that the original paint?! Wish mine was that clean!Austin
Originally posted by rustywagoneers_comi am not an addict, i can stop anytime.
Yes they are
Originally posted by Birowag'nThose wheels look great, are they stock '90 Wheels?91 Grand Wagoneer "Final Edition"
DeWooded
6 inch Hellcreek lift.
Rhino Grill
Holley 600cfm
Bit of Info
It's Maaco single stage Black Cherry paint.It's been fun driving it, the only compliment I got on the road was from an early 90's cutlass station wagon driver, it's a woody thing
. When parked lot's of people tell me how they are tanks and can handle anything.
The wheels took a total of 11hrs between the removal of the old paint and repainting and polishing the center caps and remounting them. I did it over winter break.
Step 1: lightly use the brass wire wheel going with the machining of the wheel. Use no pressure and stay till the metal looks clean. If you push too hard the brass will start to cut the Aluminum and it won't look as good..... Wonder how I know that
[IMG][/IMG]
Step 2: I mounted the center caps. All the screws were seized so I snapped them and clocked the center cap and made new holes and tapped them.
[IMG][/IMG]
Step 3: Then used 1/4 20 SS allen bolts to mount the center caps.
Step 4: removed the center caps and sprayed with Rustoleum Crystal Clear Paint with two coats waiting one hour between coats. Let dry over night and then got the new tires.
[IMG][/IMG]
The brass brush was i believe just a standard Brass sanding wire wheel. The bristles were thicker and the center was hollow. I just grabbed what i saw in the drawer and tried it. Luckily it worked out1990 Stock for nowGrand Wagoneer
U-993
Hey there Yohoo, fix yourself!!
My jeep
http://www.ifsja.org/forums/vb/showt...highlight=1990
Correct
Originally posted by jpcouttsVery Nice! The wheels look much better. Blackcherry though, right?1990 Stock for nowGrand Wagoneer
U-993
My jeep
Sorry but I scrapped the side steps, they were the type you see on the early 90's conversion cans. nothing special at least to me and with the spring sag my jeeps sat low enough without them. they were the first to go. I would give them to you if i had them.1990 Stock for nowGrand Wagoneer
U-993
My jeep
Originally posted by ajminlaHow did you polish the center caps before mounting them?
Same brass brush?
Did you spray them with clear coat also?1990 Stock for nowGrand Wagoneer
U-993
My jeep
Quick Update
Decided to waster $40 and make my exhaust a bit louder. Have a few pics of what I used and two short videos to hear the difference.
Before Video
http://s874.photobucket.com/albums/a...t=P7020010.mp4
The Supplies
[IMG][/IMG]
Finished
[IMG][/IMG]
After Video
http://s874.photobucket.com/albums/a...t=P7020014.mp41990 Stock for nowGrand Wagoneer
U-993
My jeep
Tired Of Maaco
I decided I'm tired of my Maaco paint job, it's peeling at all edges and looks like crap, So i'm painting my truck and changing the color as I go. I'm painting the Wag, dubbed "Walter" by a friend, to light blue. I am using Rustoleum hammered paint, for a more durable finish as well as a more aggressive look. here are some pics
[IMG][/IMG]
Cleaned up the rear trim as well
[IMG][/IMG]
[IMG][/IMG]
Need to refinish my screws
[IMG][/IMG]
[IMG][/IMG]
I need to finish by the 23rd for a car show i'm going to.1990 Stock for nowGrand Wagoneer
U-993
My jeep
very nice rig and thanks for the motivation to do my wheels. Mine look just like yours when you started and I want them to look like your finished product. Nice work.2000 WJ Grocery Getter and RC approved, 4'' Lift.
1983 Wagoneer Limted - Future tow rig
1988 Grand Wagoneer - All stock but super sexy and clean.
1989 6.2L Turbo diesel YJ, 6.5'' lift, 35's D44 F&R, SM465, NP205, Woody's shafts, Christmas tree air freshener.
Is that just a rattle can paint job? looks pretty good, I can see a run on the gate but looks pretty darn good.2000 WJ Grocery Getter and RC approved, 4'' Lift.
Yep
Yeah it's a rattle job, The runs in the paint are from the Maaco job, spent three hours sanding the tailgate and it was still thereDecided it was a rattle job so it won't be perfect anyway so i sprayed it. Slowly working around the truck one panel at a time masking everything off, sanding, and removing the trimmings. The bubbles in the one picture is because it rained an hour or so after I finished painting the tailgate, luckily it had no effect on the finish.
Last edited by BotterbrodtGE; 07-06-2011, 09:43 PM.1990 Stock for nowGrand Wagoneer
U-993
My jeep
That blue looks pretty good! I did a rattle can job on my waggy using about 4 coats. The coats are thinner from a rattle can. How many on yours? Replaced my cat, midpipe and put on a Cherry Bomb like yours but mine had a lower, more mellow tone. I sure miss my baby.Currently without
Formerly
1986 G.W. 360
1986 Eagle Wag
1985 G.W. 360
1984 Eagle Wag
1981 Wag 360
1978 Wag 401
1981 Cherk W/T 258
1966 Wag Super 327
Not counying XJs'.
[Did have a 94 & more recently a '97 GC with 5.2. for awhile. Just not the same! Now have the FSJ blues!
