Originally posted by Locked and Loaded
View Post
Howell TBI / EFI Installation How-To for CARB E.O. #D-452-2
Originally posted by Locked and Loaded View PostWhen you mounted the stock air cleaner where does the threaded rod go in the throttle body?
My Howell kit came with a kinda S-shaped rod that screws into the TBI body, so just thread it in and adjust to where the stock air cleaner lid will fit it. As I recall, the rod isn't tight in the body, but once the wing nut is tightened down on the lid, it's all nice and snug.
Leave a comment:
Leave a comment:
Leave a comment:
Leave a comment:
Thanks i was looking all over under the dash and didn't even think to look at the condenser. i really appreciate the help and pictures.
Lane
Leave a comment:
Originally posted by bristolf2b View PostHere’s the wires
dug & found a pic of the air box just pulled from our GW showing the thermistor connector
and, a pic of the transplanted thermistor into the new condenser
Leave a comment:
Here’s the wires
Leave a comment:
Hi MysticRob
I have my GW up and running, But i haven't finished putting the Interior back together. I can't figure out where the green wires that are part of the harness with the A/C fan wires go.
Thanks. Lane
Leave a comment:
Hey, MysticRob, am continuing the journey with our resto; was scrolling thru both your build threads to compare notes & noticed I may be missing a spring on the throttle linkage for the transmission. Do you have a clear pic of how its hooked up?
Leave a comment:
Only one wire marked "starter solenoid," their instructions say there should be two and no one at Howell gets back to me. "I" or "S" on the solenoid? Guess I'll play musical wiring if the don't get back or no one gets on here who's had this issue.
Leave a comment:
Originally posted by rang-a-stangIMHO, I would think you could wipe the hole down with a very light layer of grease, then use hot glue in there to create your own. The problem with that grommet is you could have to cut the wires to install it.
Leave a comment:
Leave a comment:
Hey, I appreciate it, but I have a salvage yard near me I need to visit at some point. I recently moved to AZ and haven't yet had a chance to get out and about to see what treasures that new yard holds, but I'll snag a couple grommets when I can.
Leave a comment:
Leave a comment:
