J20 Camper shell question
  • J20 Camper shell question
    Getting ready to fit an original Jeep camper shell on my J20 for the winter. What type of material/barrier should I use to place between the shell and the top of the bed? I do not want to put anything down with adhesive and not anything that gathers and holds moisture. Any thoughts would be appreciated.
    Thanks
    I used a 3/8" or so thick black foam indoor/outdoor weather stripping made for caps. I picked it up as Autozone if I remember right. I had to buy two rolls. This was for a factory Jeep/Leer cap I put on my 63. Sealed well. It's adhesive on one side but has a backing paper you don't need to remove.
    Similar to what Lowes has here.
    https://www.lowes.com/pd/M-D-10-ft-B...rstrip/3120623
    1987 Cherokee Laredo 2-Door 4.0/AW4
    1971 Gladiator
      Don't over think this. There are a ton of weather strip seals out there. Pick one you think works for you. My 73 came with a topper till I finally found someone (an RV shop) to give it to. It had some stick-on black rubber/foam strips on the rails. Yeah 1/2 hr clean up time once the cap was gone. I survived the clean up drill just fine but when installed it never leaked and I live in rain country. It's simple cap weather strip material not space age exotic shuttle door gaskets. The link Thomas provided should work well for you.
        Perfect! Thanks guys.
          You can always glue the seal to the cap and not the bed. I glued it to the bed simply because it's easier, but have gone the other way around in the past.
          Also, I needed to use a thicker piece on the front bed panel. My Jeep caps front flange is a bit higher than the side flanges.
          1971 Gladiator
            camper shell seal
            good idea kaiserman
            ( on affixing it to the shell not the bed )
            my only advice that may/may not help
            is to use CLOSED CELL foam
            it will not absorb moisture
            like an open cell foam would.
            J-20 with factory shell .....SOUNDS AWESOME.
            dave in NC
