J10 Chevy 6 2 Swap
Hey chvlfrk, I thought you were THE chevy guy. A 302 was a 327 with a 283 crank, in 67 it was exactly that. In 68 and 69 they had their own blocks and cranks. A 283 with a 327 crank is a 307.
Chevy didnt make powerglides in 76 and it is a very unlikely swap. Most likley a th350.
th350 pan is square with a dog earred corner. th400 is shaped like the state of texas, streached a little from top to bottom.
Ill give you any help you need as long as it not concerning defiling a Ford.
J10 Chevy 6.2 Swap.
Any progress on this? I won't be able to start on mine until after Christmas...
Leave a comment:
That sounds great! I can't wait to see how your mounts turn out! I bought my 1 ton 6.2 stuff, I just need to pick it up. This is going to be the coolest vehicle I've built so far...
Leave a comment:
If you use something newer like a 4l80e, a aftermarket controller is idiot proof I hear. That is the route I plan on taking.
As for the motor mounts, it looks like I'm gonna start tearing back into the truck the weekend after Thanksgiving. I want to do my best to do a bolt on mount, but worst comes to worse, they may end up like the LS series YJ mounts from Novak. The directions state how far from the front crossmember to weld the mounts. I welded mine in fully and never test fit the engine once, a leap of faith I know, but when i dropped the 5.3 in, it was perfect.
Leave a comment:
Originally posted by DieselSJIf this is going to be street driven, seriously consider some type of overdrive transmission. For tcase, look at a 241 from a GM/Chevy and put it all together with factory GM parts and forget about aftermarket adapters for the stock tcase.
Leave a comment:
Originally posted by thechier8610-4. I was planning on a TH400, but didn't know what t case to use for driver drop, maybe a Ferd 208? Or maybe the stock 229, if it'll bolt up. I wasn't planning on much power, so I thought it would hold up if I could use it.
Leave a comment:
Leave a comment:
Originally posted by thechier86As far as the motor mounts go, you say they mount a little bit forward of the stock location?
Is it enough to throw off driveshaft lengths and transmission mount location? I don't mind fabrication to an extent, just need to know what to be prepared for....
Leave a comment:
Great yj, man! Looks like the rust is just on the surface... I love my baby jeep, I just hate that I have to have a tent if I want to go camping. Sleeping in the back of an fsj or xj is like a hotel room in comparison....
Leave a comment:
Originally posted by KreterI'm not doing a lift kit, I'm guessing they won't cost me any more than 20 bucks a set to have cut out, I can weld them up for a few bucks, or ship them to you in pieces. I'll get them designed and post some pictures. of what I have designed once I get this bloody front clip off.
Leave a comment:
Cool find, it looks like it would bolt to my 6.2 intake, only issue is the work i'd have to do to remove all the gear stuff from the intake... granted, I'm doing a completely restro, what is a little extra labor
Leave a comment:
You might be interested in this -
http://www.ebay.com/itm/331384364670...S:1123&vxp=mtr
Leave a comment:
Sweet- keep me posted. I hope to have a 6.2 in my junk this spring...
Leave a comment:
Leave a comment:
