Exhaust Damper
Worked on the exhaust damper some more getting the holes plugged up on it.
I ran a 5/16 drill bet through the bushings in the exhaust damper.
I ran a 3/8 tap through the bushings so that I could plug it up with 3/8 bolts.
The first bushing actually took threads really well.
This is where it went wrong. I started on the opposite side and the bushing started to crumble. I took out the next size tap that would fit and cut threads straight into the cast iron. M12 x 1.75 was the tap I used.
I stopped here and went and looked for bolts to fit the new thread size ( I should of did this before I cut the threads) after several stops I was able to locate them. I knocked the other bushing out and tapped it to M12 also. the bolts fit perfect. I trimmed them down so the would not stick in to far.
I am going to use this to seal the bolts up:
I wired wheeled the damper to clean it up in preparation for painting it. It cleaned up well and will be my test piece for the finish I plan to use, which will be used on both manifolds if it works.
