Steering Rag Joint Delete
  • #31
    Originally posted by Rich88
    OK, I'm stupid on this one...
    Never had a problem with, nor ever paid attention to any rag-joint issues. So question is: What typically goes wrong with rag-joints such that an XJ lower shaft would be more better?
    It's a good upgrade if you run a bodylift too. Will definately pick up a couple since there are a ton of XJ's at my local yard.
    JR
    1966 mustang fastback
    '07 Dodge Charger 3.5
    • #32
      I did the swap last weekend. A couple notes from my experience...
      - I had to take the entire radiator/AC condenser assembly off because the GC shaft would not telescope in (to make it short enough to remove).
      - take the clamp bolt from the newer shaft home with you.
      - A few good whacks with the small sledge got both sets to separate.
      - The new lower shaft was quite a bit shorter than my '81 Wag shaft.
      Looks good enough, though.
      Don't be yourself. Be someone a little nicer. -Mignon McLaughlin, journalist and author (1913-1983)
      • #33
        So what is the purpose of the rag joint?
        1979 Wagoneer
        • #34
          I think it is supposed to dampen feedback and harshnes. I don't think any of us care about that. It also flexes to allow tiny off axis movement.
          88 GW...6.0/4l80e/241c swap. Just finishing loose ends. Old MSII TBI wasted spark for sale.
          • #35
            I got a steering shaft off a 96 xj. Shaft looks identical to the one in the post. I can't get mine to come apart. Any suggestions.
            • #36
              I hit it with an air hammer and it came right out.
              • #37
                Yup, big hammer smashing got it seperated. Feels good, but I guess I have to wait for the drivetrain to actually be in the Jeep and working to really rate it . Certainly looks better than the worn out rag joint!
