Old 03-16-2008, 07:04 PM
YoungClayB YoungClayB is offline
Finally got ALL my door locks working!!!
Hey guys,
I've hit a milestone...ALL 4 of my electric door locks are working now (up and down!!!) I know, its amazing; I can hardly believe it myself
Prior to getting them all working, I went to the local car stereo shop and had them install an aftermarket keyless entry system...the parking lights even blink when I lock and unlock the doors on my 88!!! They tried to also wire in the horn, but apparently the horn doesnt work unless the car is turned on...oh well.
For anyone having issues with either non-working or "sticky" door locks, here are the things I did that finally got them working;
- I had to replace the actuators for the driver's side doors - front and back - I ordered the OEM replacements from teamgrandwagoneer.com
- Even after replacing the actuators, the rear door would lock, but it refused to unlock. Solution: After trying MANY other things, I finally just removed the torsion spring in the door lock mechanism. Presto. There is plenty of friction in the rear lock linkages already to keep the locks from "falling".
- The front driver's side door lock (after replacing the actuator) was
intermitant. It would always "lock", but only occationally would it "unlock". This was quite the PITA since..you know, it is the driver's door afterall. Solution: First, I opened up the drivers side "switch" and noticed that the "up wire" was a little loose so I took some needlenose pliers and clamped it tight - this helped a little, but it still wouldn't unlock 100% of the time. So, I bought a "light duty" spring from home depot and rigged it up so that the spring was pulling up slightly on the actuator rod. Works like a charm now.
- The rear passenger door worked fine for a while...or so I thought. Upon closer inspection, I realized that when I "locked" the doors, the rear passenger door appeared to be locked (i.e. the plunger went down), but you could still open the door from the outside. Solution: same as the other side - I just removed the torsion spring and it actually locks now.
I found it interesting, that most of the advice on this forum for "sticky" locks is to remove the door lock assembly so that it can be cleaned and degreased. None of my door locks needed this. I actually did remove one of the rear assemblies, but once I got it removed, I realized that it was fine. After this realization, I checked the other ones by simply disconnecting the rod assembly and checking the resistance by hand.
Hurray!!! Door locks!!!
Old 03-17-2008, 06:23 AM
crispyboy's Avatar
crispyboy crispyboy is offline
YCB,
Congratulations! You are step ahead of me. I need to tackle this job but I can't get the gumption up to do any work with the winter blahs....
Steve<br />1986 J-20 360 cid/auto, trac-loc, custom efis tbi, flowkooler, aluminum cross flow radiator, rhino-liner, working AC. <br />1990 GW trac-loc, Engle cam and aluminum cross flow radiator.
<br /><br />\"The best Jeeps came from the past when gay meant you were happy and Aids was an appetite suppressant"
Old 04-04-2008, 11:44 AM
jcountryman's Avatar
jcountryman jcountryman is offline
Thumbs up
Thanks for the very helpful tip! I picked up some (4 inch springs) decorative plate hangers from the hardware store this morning and created hooks out out of the wire that hooks onto the plates and it works great. I'll post a pic later along with the item number. Took about 3 minutes to do one door.
Old 08-14-2010, 03:41 PM
Crist Clapper's Avatar
I'm being stalked by Steve... Save me!
GW: Door Lock Actuators
Hey folks, I’m about to tackle my 1990 GW door lock actuators. They all “click/work”, but some only open, some only close, that sort of stuff. I found this posting. Any other advice would be much appreciated!!! Thanks.
Originally Posted by YoungClayB
Hey guys,
Old 08-14-2010, 06:51 PM
halftrac's Avatar
halftrac halftrac is offline
What are you calling a torsion spring?
Jackie Jacob
1977 J20, 360 4bbl, 4 spd, utility bed
1978 J 10 258, 4 spd, 3" liftDD,
1988 Wagoneer Limited XJ
and a junkyard full of FSJ parts
Jake's Full Size Jeep Junkyard
www.militaryjeepers.com
Carolina Full Size Jeep Club
http://s255.photobucket.com/albums/h...eeps%20Galore/
Old 08-17-2010, 04:28 PM
YoungClayB you are a genius! I removed/cleaned/adjusted and other stuff... And could not get the two back doors to lock. Until... I removed the small spring on each as you suggested and bam! ... They work! Just like the day it was delivered. I just stood-back pushing the button watching them go up/down. A thing of beauty. Thanks!
Old 12-29-2010, 08:58 AM
Bulldoginit's Avatar
Bulldoginit Bulldoginit is offline
I appreciate you for this one. I will try this. My passenger side door will not unlock with the OEM Key fob on my 90. Thanks!
Old 12-29-2010, 10:18 AM
Billygoat's Avatar
congrats
My power locks work just fine, but the key locks are froze on Gonzo and I don't have the keys for Thumper, so I pulled the fuses.
This was after I had to climb in Gonzo's rear window because I must have bumped the lock switch.
Old 01-02-2011, 12:52 PM
KyooMac's Avatar
KyooMac KyooMac is offline
This post is worth it's weight in GOLD!
Old 03-04-2011, 11:18 PM
GWDriver's Avatar
GWDriver GWDriver is offline
BIG thumbs up and Kudos. Thanks alot.............
LarryD
USMC Retired
Good Lovin', Good Beer, and a Grand Wagoneer. What more could one want?
1984 Grand Wagoneer My therapy
1988 GMC Suburban soon to be retired. . .SOLD
2006 Hyundai Sonata GLS/LX Wifes DD
2003 Dodge TD 4x4 long bed
Old 03-05-2011, 02:12 AM
Tripwire's Avatar
Tripwire Tripwire is offline
SWEET! it can be a biatch (sp) sometimes
Abort? Retry? Ignore? >
Old 10-30-2016, 08:25 AM
asudchiman's Avatar
asudchiman asudchiman is offline
Lightbulb
Wow! How have I not see this post before?
Hopefully, this just saved me a lot of time and agony trying to get my door to unlock again.
1985 Grand Wagoneer - [Blue]
1990 Grand Wagoneer - [White]
1991 Grand Wagoneer - Vin#...001 [White]
1991 Grand Wagoneer [Hunter Green]
4rd: 2005 Jeep Wrangler LJ (Sold)
3rd: 1987 Grand Wagoneer (Sold)
2nd: 2005 Grand Cherokee Limited 4x4 Hemi (Sold)
1st: 1993 Wrangler Sahara (Sold)
Blogs:
Primary:My Jeep and Me
Old 10-30-2016, 11:38 AM
serehill serehill is offline
Gone,Never Forgotten.
ABSOLUTELY
Great thread.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 10-30-2016, 12:20 PM
I just went through all mine and found if they work too well they will lock on you when you close the door. Not a good thing if you hop out to check the mail or 100 other somethings and close your door and lock your keys inside.
Found most of the latch springs sheared off and clinging on in the grease so they still provided just enough resistance to keep the heavy pull handles from dropping. So when you clean out the metal pieces and lubed them up they would drop very easy Into lock position on you.
GM steering column blinker cam return spring is a close fit if you're good at minor modifications a clip here and a bend there will make it work it's thin to fit.
I got the BJs spring kit and the spring is very thick to fit between the moving parts and rubs and is very stiff. I broke one trying to Install on drivers door so I used the other one for the back for drivers. Very stiff, So much that I worry I'll break the key off trying to unlock it. I hope it breaks in.
I think honestly if you can leave just enough dirt in the mechanism and your old spring pieces, to where it doesn't drop on you, and the actuator lifts it smoothly then you'll have achieved enlightenment and a happy medium.
If your a perfectionist and want it clean and proper then your in for a struggle.
BJs off road has a tutorial to show you how to change these out on the website where you purchase the replacement springs.
