Closed Thread
Old 10-10-2006, 09:53 AM
Blinkinlights's Avatar
Blinkinlights Blinkinlights is offline
Rear Main Seal Replacement
I just repalced the rear main seal on my '87 360, with a lot of help and encouragement from HARDCORE pacer, and it wasn't that bad. For those of you that are thinking of doing it, here are some pics.
First of all, I took off the starter and then removed the oil pan. I actually removed the 727 tranny inspection cover, thinking that I could get more room for the back 2 bolts, but it didn't matter. I did need to unbolt both sides of the exhaust from the manifolds to get enough room to drop the pan. My Waggy has a BJ's 6" lift, 33's and I did the whole repair without lifting the Jeep at all. I found that there was enough room for me to slide under the diff while on a creeper.
Then I needed to clean off the old gasket material from the pan and the bottom of the block. For the pan, I used a metal brush wheel on a drill, and for the block, I used a scraper that I had sharpened up on the grinder. I then cleaned out all the crud in the oil pan with varsol and then finished it up with brake cleaner.
I also pounded straight the flanges on the pan so that it would seat properly against the block.
Now it was time to remove the rear main cap. It was a bit of a PITA because it's torqued down to 100lbs. pressure, as stipulated in the TSM. I was told to be careful to keep the dirt off the half of the main bearing that I removed and made sure that it was clean and oiled when I put it back on.
Here's a pic with the main bearing cap removed. You can see the rear main seal just below the lip on the crank. I've already tapped it out from the other side.
Now the TSM states that you need to loosen the other main bearing caps, but EXTREME pacer said that he'd done it many times successfully without touching any of them, other than removing the rear. It was a real PITA to get at the seal to tap it out with a long skinny punch and I was beginning to doubt Craig's instructions when it suddenly came loose. Once it was moving, it came out rather easily. I then reversed the process and installed the new seal the same way that it had come out. Be careful installing the new seal as if it is not snug against the crank, you can easily carve off some of the seal when pushing it back in. Don't ask me how I know that.
Now, it was time to replace the other half of the rear main seal, which is rather easy when it's off the motor. Additionally, there is the pan seal that has to go on the outside of the cap. The TSM instructs to put some RTV at the ends of the pan seal as it looks like it is too short when you first put it in. Once it's torqued down, it's fine.
Thje one confusing thing I read on the pan gasket box was about putting some RTV on the chamferred edge but not on the flange between the main cap and block. I finally figured it out from the diagam in the TSM and it was here.
Next was to remove and install the new front pan seal, which was covered in RTV and was a little difficult to remove.
Finally, made sure that the bearing was clean and oiled, installed the main cap and torqued it to 100 lbs, first doing both bolts to 25lbs, then 50, then 75 and then finally 100. Then I ran a bead of high heat RTV gasket maker on the block, placed the cork gasket halves on top of that, and then ran a bead on the oil pan. Another tricky part was getting the pan back on the engine without getting RTV over everything. I put in the pan bolts just finger tight, left it for 24 hours to set up,and then torqued the large 6 bolts down to 11 ft/lbs. and the smaller ones until I saw the cork gasket starting to squeeze out. I filled it with 5 quarts of oil after changing the filter and started it up.
All in all, it would have probably taken me 3 -4 hours to get it done if I didn't have to leave to get some actual work done, but it wasn't that bad a job. I'm not a mechanic but I did rebuild my NP208 last year and it works.
The cost of doing this yourself is about $40.00 CAN and your time. Great payoff of stopping the puddles on the floor, for a few hours and $40.00.
Greg
87 Grand Wagoneer 360/727/NP208
BJ's Front and Rear Dozer Bumpers
35x14.5x15 Boggers on 15x10's
Mile Marker H10500 Hydraulic Winch
http://photobucket.com/albums/y174/bANGr/
It's all fun and games until someone breaks a woodie.
Old 10-10-2006, 03:00 PM
johnwaynejeep2
Posts: n/a
Archive material
I agree with PB, this is a great archive writeup. straight forward with excellent pics. I did this over this past weekend also and would like to add a few things which I encountered.
The exhaust Y pipe can be a pain in the neck to remove if it's never been taken off before. I had to take my waggy to a muffler shop and have them put in another sleeve joint where the driver side pipe coming off the manifold meets with the pass side pipe. this was the best place to put in a joint that would still allow me to have full access to the oil pan. It cost me about $25 and was well worth the money for the added convenience of only removing 2 exhaust manifold bolts and having a fresh non-frozen sleeve joint to work with.
The air injector hose that ran from the engine bay to the catalytic converter was in the way of removing the oil pan. The joint near the cat was also frozen, since this hose has long been disconnected from the air pump I just decided to remove it with a cutoff wheel at the catalytic converter joint instead of fighting with it. I didn't bother putting it back in.
I also had to drill and retap the oil pan drain plug, I figured it was easier to do this with the pan out anyways. It was easy to drill and retap and now I have a new 5/8 drain plug . Apparently this has happened several times before and the plug just keeps getting bigger. None of my sockets even fit the head anymore.
Old 10-11-2006, 03:47 PM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
Greg was able to remove the pan by just hanging the y pipe down which is how I would have done it (if I still had one with a y pipe). so having the exhaust out of the way would be nice it is not necessary to remove it to complete this just undo the manifold to pipe nuts and drop the exhaust down as far as possible. One note to add is when you go to tap out the old portion of the seal from the block there is a steel reinforcment imbedded in the seal and it is the end of that you need to tap on not on the rubber portion of the seal. Also really oil up the new seal half before attempting to install it and as you rotate the seal half into the block apply gentle pressure on the seal against the crank to help it go in easier and not deform or peel the rubber.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 10-11-2006, 05:30 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Following Spectre's assistance we used hylomar for the cork gasket and it required zero set up time for final torque. Also cleaned the pan bolts well and used thread locker.
Closed Thread
