Old 05-10-2006, 06:06 AM
crispyboy's Avatar
crispyboy crispyboy is offline
I did a search on the Hella Vision Plus headlamps - they use a hb2 9003 bulb. Is this different than the h4 bulb?
Steve<br />1986 J-20 360 cid/auto, trac-loc, custom efis tbi, flowkooler, aluminum cross flow radiator, rhino-liner, working AC. <br />1990 GW trac-loc, Engle cam and aluminum cross flow radiator.
<br /><br />\"The best Jeeps came from the past when gay meant you were happy and Aids was an appetite suppressant"
Old 05-10-2006, 07:33 AM
crispyboy's Avatar
Here's an interesting article on light bulbs.
http://www.danielsternlighting.com/t...good/good.html
Old 05-10-2006, 09:00 AM
Spectre's Avatar
Spectre Spectre is offline
I have to disagree with Mr. Stern (and have before) on the topic. First of all, the SilverStars don't seem to be short-lived; I do a lot of night driving and I get at most a couple years out of bulbs anyway - these seem to be holding up just fine at a little over a year.
He is correct about the light appearing whiter; but what he does not discuss is the sealed-beam replacement units. He's talking specifically about using the bare bulbs in an OEM headlight unit like the kinds found on, say, a new non-HID Honda Accord or Toyota Camry or Dodge Ram. In that case, no, the SilverStars have no advantage whatsoever over a normal bulb other than cosmetic appearance. However, when a SilverStar bulb is combined with the Sylvania Performance reflector and lens (i.e., their H6054 replacement sealed beam, which is what is on my Jeep), it's an excellent upgrade, the best DOT-legal pattern I've seen. The reflector and lens is what makes the difference in this case.
That said, if you want excellent DOT-legal lighting performance that's identical to the SilverStars (right down to the lumen performance as measured by my photometer) save for the cosmetics of a whiter light, get yourself some Sylvania XtraVision H6054's. They're $5 cheaper apiece; they use a high-output 'unfiltered' halogen bulb in the same reflector and lens assembly. It produces "traditional" colored halogen light, that's the only difference. The pattern the Xtravision throws is identical.
If you're willing to put non-DOT legal gear on your truck and risk a ticket or failing inspection, then I'd go with some Hella or Autopal H4s. I do that on my Jaguar XJ sedans because since it's an unusual European car, *nobody* knows what it's supposed to have and you can get away with almost any modification on it. The Jeep is an American car with a common knowledge tech base, so there's less I can get away with - especially since I live a block from the local cop shop.
"Battlewagon": 1986 Jeep Grand Wagoneer (w/ Tow Pack) - Urban Assault Wagon under construction - TFI, TBI, CS144, Aftermarket Sanden, Explorer Power Seats, 4" Lift, 16" AHI wheels and much much more; click here for a full list of modifications and gear, links to writeups/posts and more info.
Daily Driver: Modified 1987 Jaguar XJ6 Vanden Plas.
Old 05-10-2006, 09:07 AM
Sbonley Sbonley is offline
In my first Cherokee I put the Cibie' lights in with 55W low beam 100W high beam after several years of this everytime I hit the highs all of the lights, including dash, would go off. I blew the engine shortly after that so I never got it fixed. With the next Jeep I put the Hella's in with stock wattages. Both are a vast improvement over the stock lights but I prefer the Cibie' lights. Last weekend I put in the Painless H4 wiring harness and put the 55/100 bulbs back in. You could see the difference even with the stock wattage low beams over the stock wiring harness. Just a long way of saying Yes go with the H4 headlamps and a wiring harness with relays coming from the battery for full voltage to the lights.
\'79 Cherokee Golden Eagle<br />Mostly Stock (for the moment)
