Old 08-13-2000, 03:14 PM
FSJman FSJman is offline
Angry
I have an 84 Gran Wagoneer, with select trac. My flex plate ring gear is shot. I'v been told that the flex plate and torque converter are welded together. If so where can i find one?
Also does any body know of a manuel tranny that will work with select trac, with out buying a bunch of adapters?
thanks
FSJman
AMC 360 bored 60 over
Edelbrock 650 s/p carb
accel super coil
custom exhaust
3 inch body lift
31/10.50 BFG's
Old 08-14-2000, 12:26 AM
Drew M Drew M is offline
Smile
[quote]Originally posted by FSJman:
[b]I have an 84 Gran Wagoneer, with select trac. My flex plate ring gear is shot. I'v been told that the flex plate and torque converter are welded together. If so where can i find one?
ANS> You have been mis-informed as to your torque converter design. Although the automatic transmission in your Wagoneer is a Chrylser design, which usually use a torque converter with a starter ring gear welded onto it, your ring gear is part of the flexplate, which attaches to the AMC Torque Command torque converter by four (4) bolts. Therefore, you can change the AMC starter ring gear without changing the toque converter or welding.
As to which manual trani fits, call Advanced Adapters and ask. If you don't mind the Dana 20 t/c, you could swap in a manual T18/Dana 20 from a J-truck.
-Drew M.
Old 08-14-2000, 02:59 AM
Wink
<BLOCKQUOTE>quote:</font><HR>Originally posted by Drew M:
[b][quote]Originally posted by FSJman:
-Drew M.
<HR></BLOCKQUOTE>
Drew, on an 84 he'd have to swap axles also if he wants to use a D20 x-case. The D20 is a right side drop and the 80 and up FSJ have the front pumkin on the drivers side(left) and a centered rear. Be easier to use a Jeep version NP208 from an 80 up which is left side drop.
-joe
Old 08-14-2000, 09:19 AM
Wink
Thanks for the info. That helps.
FSJman
amc 360 bored 60 over
edelbrock 4bbl 650 s/p carb
accel super coil
coustom exhaust
b/m star shifter
3 inch body lift
coustom front bumper
tow package
31/10.50 BFG AT
