Old 07-01-2019, 04:42 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Body bolts..
I searched the archive page.. just a bunch of yuk yuk about body lifts. So.. What size bolts do we need to reinstall a new set of body mounts? purchased a set but no bolts in it! If anyone has this info, it would make a great sticky or archive.... Thx
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 07-02-2019, 03:24 PM
fsj454 fsj454 is offline
Long time member
ace hardware
I found at ace hardware 7/16 thread .
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 07-02-2019, 04:18 PM
jeepman1's Avatar
We'll see
Found a Fastenal near me, they have every bolt in the world! So I got some 4 and 5 inch 3/8 hardened bolts and big washers, we're gonna make our own.
: 98 9er
'83 Honcho j10
Old 07-07-2019, 07:14 PM
FleetFox FleetFox is offline
ditto on Fastenal, if it's an 83 J truck likely 7/16" coarse thread. Ask for Flange head bolts. Ebay or Amazon are second options.
Fleet Fox
Old 07-08-2019, 04:49 AM
SC/397's Avatar
SC/397 SC/397 is offline
I buy just about all of my bolts through McMaster Carr. I am sure that you cold find the bolts that you need as well. Ships right to your door.
https://www.mcmaster.com/#
Old 07-09-2019, 04:36 PM
jeepman1's Avatar
He has a lot of stuff.. does he know anything about FSJ's - or when you order from them ,they expect you to know (as we should) what we're ordering...?
: 98 9er
'83 Honcho j10
Old 07-09-2019, 05:04 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
McMaster Carr is an industrial supplier, not a person. Orders are primarily done by part numbers; their website is pretty decent to navigate. You could likely call a rep and get help searching for something, but their inventory is absolutely enormous, so it might take a while to do it that way.
Old 07-10-2019, 07:04 PM
nograin's Avatar
nograin nograin is offline
This thread and links should get you started: Body Mounts
http://www.ifsja.org/forums/vb/showthread.php?t=178320&highlight=bolts+body+mount s
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
How much torque to body bolts duracell General FSJ Tech 6 11-29-2016 11:23 PM
Body Mount Bolts Thomas792 General FSJ Discussion 4 10-21-2009 10:54 AM
Continuing Saga of the Water Pump/Timing Cover Bolts . . . 88sunroof General FSJ Tech 30 05-09-2009 07:03 AM
body bolts grand350 General FSJ Tech 3 11-13-2005 02:59 PM
Body mount bolts bosted loose, now what? ohioj20 General FSJ Tech 7 09-11-2005 10:47 AM
