Old 06-27-2019, 02:27 PM
DBX11's Avatar
DBX11 DBX11 is offline
Update
Finally took off the stock intake and mounted the used performer from eBay and the edelbrock 1405 from a fellow member and it runs a lot smother with Gobbs of power! Not sure how much seat of the pants hp but I can definitely feel a change it seems to breathe better and the 268h is awesome! Thanks Rick the engine now has about 500 miles and is kick A$$ !! The th400 I rebuilt with my two oldest boys seems to shift up and down with no issues so congrats to me!
Old 06-28-2019, 07:02 AM
SC/397's Avatar
SC/397 SC/397 is offline
Old 06-28-2019, 04:36 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Originally Posted by SC/397
I finally took a 360 apart that looked really good inside. Good enough to throw new rings, bearings, cam at it and go. Basically, other than hot tanking the block and honing it, it didn't need any machining. The timing was right for DMX11 because he was in need of a engine in kind of a hurry. So, a refresh with the 268H Comp Cam. One of my favorites for a 304 or 360.
360268H by Rick Jones, on Flickr
I had to finish this one up before I could get to it though. A 401 with a Cross Ram and dual 600 Holleys. I put the small 280H cam in it and compression is at 9.5:1. All the wrong parts it seems to me to go under a Cross Ram but it is a street car application that just has to look cool. Amazingly enough, it runs like a top and takes all of the carburetion well. It doesn't put out as much power as a Torker with a single 4 barel does but cool it does look.
401xram by Rick Jones, on Flickr
XRamIMG_3128 by Rick Jones, on Flickr
Do you have the timing set (hooked up to vac) in that sound bite? I have same cam and single 4bbl, but mine sounds like a kitty cat.
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 06-29-2019, 06:10 AM
SC/397's Avatar
I can't remember but I think so. The idle was set pretty low and the mufflers are straight through which is why it might sound a little more aggressive.
Old 07-07-2019, 10:15 AM
Do you have headers or manifolds? Do you have a cat? I have a 268h going through headers, a single 3 inch exhaust, and a borla almost straight through muffler and it is pretty obnoxious.
Old 07-08-2019, 03:01 PM
DBX11's Avatar
Stock manifold, no cat 2 1/2
Old 07-14-2019, 02:33 PM
SC/397's Avatar
Here is one that I am finishing up for a Jeep SCRAMBLER. It is a 8.5:1 360 with a 268H cam and Torker intake manifold. The 268H is really not a big cam compared to a stock 401 cam. It has more duration and a more narrow LSA.
Stock 401 Cam: 208/210 @ .050" .458" valve lift and 114 LSA
ComCam 268H: 214/214 @ .050" .456" valve lift and 110 LSA
Stock 360 Cam: 196/196 @ .050 .426" valve lift and 110.5 LSA
IMG_1867 by Rick Jones, on Flickr
Old 11-11-2020, 11:33 AM
DBX11's Avatar
Just installed the summit racing brand CDI ignition box and it starts faster goes faster and sounds faster!
Old 11-13-2020, 07:01 AM
DBX11's Avatar
Going from the old ignition box to the cdi is a major difference I had already put the big cap and rotor on and the Jeep is utilizing the 268h to the max. Need to take a long drive one day and log in some mpgs. maybe I should look into the broken fuel gauge issue next.
Old 01-15-2021, 10:04 AM
DBX11's Avatar
Update
Summit racing cdi box was tested last week took a two hour drive just fine. I did pull the initial timing back a touch along the way tho.
Old 01-15-2021, 10:13 AM
Did you log MPGs?
Old 01-15-2021, 10:46 AM
DBX11's Avatar
No, the goal was fill up drive 100 miles then fill up again then do the calculations but I never filled back up when I got home. Next time I go out with it tho... I
amc 360 vs dodge 360 Carleysjeep General FSJ Tech 37 05-13-2009 10:56 PM
AMC 360 to CJ 5 Swap CJ Runner Off-Road FSJ Tech 4 10-31-2008 10:52 AM
AMC 360 cam gear issues Cartman General FSJ Discussion 1 10-20-2008 07:00 PM
will a 2barrel carb off 360 fit 304? Robber80 General FSJ Tech 7 05-03-2006 06:39 AM
360 better than 258?? Scruffy Engine 6 07-24-2000 08:04 AM
