Old 01-11-2012, 01:23 PM
87Gray's Avatar
87Gray 87Gray is offline
J10 springs into GW
Stripping down a 80 J10 Laredo, and building a 1987 GW. The GW has the usual wag sag, while the J10 sits high and even. What is the stock ride height spec. for the GW and the J10, and will the springs from the J10 fit the GW? Will it give it any lift? Thanks in advance!
Old 01-11-2012, 02:12 PM
Julep4000's Avatar
Julep4000 Julep4000 is offline
Aside from the spring rate they should be the same...
'72 J4800
360/TH400/D20
Old 01-11-2012, 02:32 PM
87Gray's Avatar
According to the measurement specs I saw, the sizes are correct. I'm assuming the J10 springs will ride harder? The spring rate will affect the ride height, but by how much?
Old 01-11-2012, 04:22 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
If you had the actual spring rate numbers and the weight of each vehicle, you could probably calculate it out.
Old 01-16-2012, 01:03 PM
87Gray's Avatar
OK. I took a look at the springs on both trucks, the J10 has a 7 leaf pack, the GW has a 5 leaf pack. I cannot find any definitive answers in the searching I've done. The length should be the same, but I've heard the centering pin is spaced differently. Mostly interested in swapping the rear springs only, but may decide to do the fronts as well. Alot of conflictictions out there, someone set me straight. Here's a link I was looking at for specs., but according to this I don't know if they are correct.
http://www.generalspringkc.com/index...arent=145&pg=1
Old 01-16-2012, 01:32 PM
Well considering the lift kits for a GW and a J-10 are the same I would assume the stock springs would be interchangeable. I also would assume that the J-10 springs are a heavier spring so that should jack up your rear a little but I doubt by a whole lot.
-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
OE Stock Tire Size for '82 J10 -or- Accurate Speedos The PIG Smith General FSJ Tech 12 09-12-2014 04:00 PM
74 J10 Springs Chris P. General FSJ Tech 3 04-05-2006 06:16 AM
Kinda OT question about springs JeepsAndGuns Off-Road FSJ Tech 10 04-05-2004 08:31 AM
Rear springs on a bobtailed J10...Waggy fronts? Cary Off-Road FSJ Tech 4 01-08-2004 04:13 PM
Saggin Springs frozen General FSJ Tech 3 01-06-2002 04:49 AM
