Project: Alice
  • rwjohnstone
    • Jul 17, 2011
    • 103
    This past weekend I got the motor positioned where it needs to be on the frame. Now I need to make a few adjustments. Once I get my camera back I will go into some more detail, but I think a few more inches of lift are instore for Alice...
    Now it comes to the radiator... Stock, the truck came with a 3 core 17"x22" in decent shape.. only problem is the outlets are only 1.5".... I know there are a ton of posts and threads about this same topic and soon I will have a full writeup on the research/future plans to keep this beast cool. For now its back to work, and later, back to welding... ah the things we do to drive Jeeps....
    "Decide what to be and go be it." - The Avett Brothers
    1964 J-200 "Alice" Build Thread:
    http://www.ifsja.org/forums/vb/showthread.php?t=150066
    1979 CJ-7 (s) - Status: Dismantled Hibernation
    1981 J-10 - Status: Parts? Daily Driver? Lawn Ornament?
    1993 Cherokee Sport - Status: Sold (408,000 miles)
    • JeepinPete
      • Dec 09, 2003
      • 2190
      I wouldn't be surprised if a stock V8 sized radiator would be plenty to keep the Cummins cool. The more efficient an engine, the less heat it throws into the cooling system. A Cummins is arguably pretty close in displacements and power output to a AMC V8, but a heck of a lot more efficient.
      Pete
      Isuzu 6BD1, NV4500, NP241
      • jeepmj_tj
        • Aug 09, 2006
        • 212
        my stock v8 radiator keeps my 6cyl cummins cool. only time the electric fan comes on is in hot summer traffic or towing up grades. no mech fan either.
        01 TJ-Trail rig
        91 MJ-Play toy and work horse
        79 J20 Tow Rig- Cummins 6 cyl, DD since 07
        • rwjohnstone
          • Jul 17, 2011
          • 103
          I know the Cummins is a cool running motor and very efficient, in my mind its the only option for a diesel, I just want to build everything up now while I can plan for it. One day if all goes well I would like to get a larger turbo, P-Pump, injectors, and a jake brake. So I might as well build it big now or design it to easily accommodate a larger cooling system if needed. Hopefully I will have some pics up tomorrow sometime...
          • 76FSChief
            • Feb 19, 2010
            • 401
            I am using the stock 360 rad for my Cummins swap! Spent some time on the Cummins forums researching the issue. Lots of people were using their stock rads for swaps.
            • JeepinPete
              • Dec 09, 2003
              • 2190
              RW, a question on the gauges. Is the glass flat or domed?
              Pete
              • rwjohnstone
                • Jul 17, 2011
                • 103
                The glass is domed. Cant wait to put them in. Need to know anything else?
                • rwjohnstone
                  • Jul 17, 2011
                  • 103
                  All right, I know that one of the main concerns when doing this swap is keeping this engine cool so here are some specs and details from searching around on this site and others.
                  Stock Dodge radiators:
                  1990 Dodge W250 Standard(w/o inter-cooler) - 15.75" x 30.25" x 1.5" (2 Core)
                  1994 Dodge Ram 2500 (w/ inter-cooler) - 36" x 19.25" x 2.25"
                  1999 Dodge Ram 2500 (w/ inter-cooler) - 36" x 19.25" x 2.25"
                  Stock Jeep radiators:
                  258 six cylinder - 16.25” x 24.25” x 1.25”
                  360 V8 -15.875” x 26” x 2” (3 core)
                  -or- -15.875” x 26” x 2.625” (4 core)
                  I know there are some differences through the years but these are the most common and best numbers for "approximate" measurements for Jeeps
                  Radiators different members have used in their 6bt swaps:
                  Budojeepr - Flex a lite 56000L - 26” x 18” x 3.75”
                  Well, I've gone and done it...started the body swap. Last year I bought a non-running '72 Wagoneer (thread link (http://www.ifsja.org/forums/vb/showthread.php?t=106370)). I figure that since I've had so much trouble (thread link (http://www.ifsja.org/forums/vb/showthread.php?t=80533)) trying to register the '81 diesel
                  Resbum - Flex a lite 58000 - 33.625” x18.5” x 3.75” 2 core
                  Excuse the long-winded intro. I need to give credit where it’s due. If you want to get to the meat and potato’s jump to the next post. I waited until now to start the thread because I wanted to be sure I could actually pull this off before embarrassing myself. First off I need to give some well deserved credit to
                  Mikel - Summint Racing - 27” x 19.625” x 2.25” 2 core
                  http://www.ifsja.org/forums/vb/showt...=131069&page=3 - (post#29)
                  Several others are using stock radiators and claim to have no issues keeping this engine cool no matter how/where they drive or what they are pulling. Most people have an electric fan setup of some sort, commonly from a Taurus or a few from an XJ.
                  I do believe I am satisfied. My stock radiator should work just fine....for now
                  Many people have done this swap and left the stock radiator from their 360 or even 258 motors and have not had any problems.
                  • Resbum
                    • Jun 16, 2010
                    • 648
                    Great post full of good info for people doing swaps. Thanks for taking the time.
                    Resbum
                    Originally posted by Resbum
                    "What year is my truck?... Which part?" Build thread- http://www.fsjnetwork.com/forum/view...p=18290#p18290
                    • rwjohnstone
                      • Jul 17, 2011
                      • 103
                      Resbum
                      no problem, i know i am not the only one who has done that, I will add to it as time goes on and I find more info/links. Just trying to give back for all the knowlege you and others have shared with me.
                      • jeepmj_tj
                        • Aug 09, 2006
                        • 212
                        #41
                        The only thing that I have had to do to my stock radiator was have the lower neck above the steering box turned 90* and point toward the passenger side. This allowed me to run a crossover lower hose.
                        01 TJ-Trail rig
                        • rwjohnstone
                          • Jul 17, 2011
                          • 103
                          #42
                          I brought the engine to a friend of mine to get it cleaned up and do some of the simple things to it, I need to get the truck out of the shop as soon as possible, so I am trying to get everything that requires heavy lifting done so I can bring it home to my shop. List of things for the engine: Killer dowel pin, rear main seal, throw-out bearing, pilot bushing for clutch, 60 lb. springs, general clean up and paint.
                          We took the timing cover off the other night to do the dowel pin, only problem was.....the pin is gone....after doing some research online I am one of only a handfull of cummins owners that have had the pin fall out and not go rocketing through the side wall/blow up the engine on the planet. I have really really good luck and really really bad luck, there is no in-between it will be one or the other. Camera will be back soon, transfer case cross member is half built, front to be lifted up, and lots of welding this weekend.....
                          • lobie
                            • Feb 25, 2011
                            • 446
                            #43
                            I've read about the pin coming out so I opened my cover up. The pin was almost about to fall. I did the pin trick and also tightened some of the bolts in there.
                            77 Wagoneer | 6.0 | TH400 | NP205 | Sterling 10.5 | Dana 60
                            07 6.7 Cummins 2500 4wd
                            lobie4x4.com
                            CFSJC
                            • rwjohnstone
                              • Jul 17, 2011
                              • 103
                              #44
                              Nice catch, not many people have it come out, guess we are just lucky
                              The tranny was pulled off, throwout bearing was about gone, input shaft a bit grooved, not too bad. Clutch is muticolored and abused. Now the hunt for a new clutch begins....any suggestions? Going to search after work today....
                              • lobie
                                • Feb 25, 2011
                                • 446
                                #45
                                I have ordered from phoenix friction before.
                                Premium OE and performance clutches and brakes. Clutch Kits, flywheels, brake pads, rotors, shoes and drums for automotive, medium and heavy duty vehicles.
                                lobie4x4.com
                                CFSJC
