Old 02-02-2011, 12:14 PM
shadow1991's Avatar
shadow1991 shadow1991 is offline
Guess what broke now...... HELP!!
My front body mount bracket is broken. I guess this is common, has anyone fixed one or have any advise how to get the old one off. I see BJs is selling a replacement for $40. Thanks
Btw I tried to upload a photo but cannot get it sized right.
Proud Veteran and Proud Wagoneer Owner!
1990 Grand Wagoneer
4 Inch Lift, 360 bored .30
how much money I have spent?!!
Old 02-02-2011, 12:37 PM
1jeep's Avatar
1jeep 1jeep is offline
What do you mean broke? PM me the photo and I'll resize it. Or open a photobucket account and you can do it there. Pluse it's easier to load pictures that a way.
Old 02-02-2011, 12:49 PM
shadow1991's Avatar
ok here we go
http://s1213.photobucket.com/albums/...IMAG0091-1.jpg
Thanks
1990 Grand Wagoneer
Old 02-02-2011, 12:58 PM
Last Mohican's Avatar
Last Mohican Last Mohican is offline
Got a torch???
"When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of!"
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[ ]llllll[ ]
_.(o)_)__(o)_)--o-)_)
Old 02-02-2011, 01:02 PM
Billygoat's Avatar
wow, I have not seen that before
A good right angle grinder can take the heads off, then a punch to knock them out.
Old 02-02-2011, 01:04 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
those rivets are soft. I have removed them with a good chisel, or jost grind the heads off and punch them through. What is going to be fun, is putting it back on, I beleive the frame is boxed at that point.
Old 02-02-2011, 02:23 PM
GallionSW's Avatar
GallionSW GallionSW is offline
Thats a new one to me!
JEEP-JustEmptyEveryPocket
1988 Grand Wagoneer
1983 CJ7
Old 02-02-2011, 04:14 PM
shadow1991's Avatar
Thanks guy, I am sure I can get it off but puting one back on will be another story.
1990 Grand Wagoneer
Old 02-02-2011, 08:52 PM
shadow1991's Avatar
any suggestions for replacement rubber?
1990 Grand Wagoneer
Old 02-03-2011, 06:14 AM
I found the best way to remove rivets is to cut an X on the head with a die grinder and cut-off wheel then chisel them off. I can't see the pictures but it seems to me the installation would be easier than removal.
Resistance is not futile yet.
Old 02-03-2011, 06:56 AM
J20 project's Avatar
Well, unless going for the perfect resto look, I don't believe strength would be a problem if you just welded the dang thing up.
J20
BP Drivetrain...........
775-537-7918
Old 02-03-2011, 07:05 AM
J20
I agree, I've fixed at least a half dozen like that.
Usually need to sort of jack it back into position a little, then just weld it up.
If you don't weld or don't want to mess with it, that's like a 20 min job for anyone with some skills and a mig welder.
Old 02-03-2011, 07:42 AM
austinaubinoe's Avatar
BJ;s sells a Poly body mount kit. I replaced the mounts on my TJ with poly and it significantly stiffened body roll.
Old 02-03-2011, 08:22 AM
seventynine's Avatar
I agree...weld it up and move on to the next problem
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
'13 FLSTN Softail Deluxe
Broke on the Con mrs General FSJ Tech 10 08-21-2010 09:46 AM
my hood release cable broke... Dude23455 General FSJ Tech 4 05-05-2005 04:52 AM
Update to "is this a blown head gasket?"(its a broke piston) JeepsAndGuns General FSJ Tech 17 09-07-2004 10:55 AM
did the threads but broke the coolent intake! Drivir8 General FSJ Tech 3 09-21-2003 01:14 PM
I think I broke my Vacuum Distributor?? Darin General FSJ Tech 2 08-06-2001 05:46 AM
