Old 05-09-2009, 01:07 PM
YoungClayB YoungClayB is offline
Quick question about a fuse problem...I think
I think I am having a fuse problem, but am not quite sure which fuse to replace or where its located.
I have a 1988 GW
When I turn my headlights on, the illumination behind my instrument panel goes off; including the digital clock...when I turn the headlights off, the clock comes back on.
Can someone please help.
Thanks,
-Clay
Old 05-09-2009, 03:25 PM
I have a 1988 GW
Thanks,
-Clay
Likely culprit is grounding issue...
Follow the Black Ground Wire @ B-19 and insure that it has a good ground.
http://oljeep.com/gw/elec/88/88_FSJ_...agramPage5.jpg
Old 05-10-2009, 02:02 PM
I am not great with electrical. Can you try to describe where this black ground wire is on the vehicle itself?
I also forgot to mention that this is a new problem that just popped up a couple of days ago- which is why I thought it might be a bad fuse
Old 05-10-2009, 02:29 PM
mystery solved. It was the 3A fuse labeled ACC LPS
