  #41
Old 03-07-2021, 02:25 PM
SC/397's Avatar
SC/397 SC/397 is offline
IMG_4415 by Rick Jones, on Flickr
106. PaulA360: Jeep Pickup 6 cyl replacement TH400. Done!
98. VL390: 1970 Javelin street car. Assembling now
56. CD418Stroker: Done! Lots of nice parts in this one..
IMG_4424 by Rick Jones, on Flickr
97. SC397: 360 bored and stroked to 397. At the Machine Shop. I am in no rush
103. TE401: 401 with Eddy heads for a Spirit. At the Machine Shop
104. Rozwell343: Cam bearing issue rebuild.
105. xranger360: On Hold
107. Comando360: For Javtwotone. Need to prep his block
108. NEJoe360; For his '70 AMX. Need to disassemble.
109. Mld911304: A hot 304 for a CJ5. Ready to Assemble
110. SteveC343: Rebuild for a Buddy's 69 AMX. Last one for this year.
Old 03-10-2021, 02:54 PM
that is a site to behold
even if you don't like vehicles
that is impressive.
dave in nc
Old 03-17-2021, 02:51 PM
SC/397's Avatar
Here is the latest version of my waste oil burner. I had made a wood stove conversion that worked OK but I couldn't trust it. If I could sit there and watch it and adjust the oil flow and air flow every 10 min or so it was fine. It was either an inferno or the fire would go out. If the fire went out, the pot filled with oil and then I had to bail it out. It would get so hot that it warped the inside of the stove. The stove had seen better days anyway so now it is scrap metal.
Enter the Siegler.. I bought this one of of CL a few years ago. It is exactly like the one that my Grandpa had. I cleaned out the carburetor, re-plumbed it with a secondary filter, and put a new blower in it. The plan is to start it on Kerosene and once it is going switch it to my waste oil blend. The first batch was a 50/50 mix of used 10w40 brake-in oil and #2 fuel oil. I know the key to burning this stuff is to get all of the particles out that I can. The carburetor jet is small it it won't take much to plug it. I poured the mixture through a paint strainer before I put it in my tank.
IMG_4422 by Rick Jones, on Flickr
IMG_4453 by Rick Jones, on Flickr
Wide open on Kerosene>
IMG_4458 by Rick Jones, on Flickr
Wide open on waste oil/fuel oil blend>
IMG_4460 by Rick Jones, on Flickr
Old 04-05-2021, 05:53 AM
SC/397's Avatar
Road trip last week wend to dyno a engine and pick up the 2nd convertible parts car.
56. CD418Stroker: Full ported Indy Heads, 12.8:1, E85, 267/275 @.050, 108LSA, ,704" lift solid roller cam, Torker intake, 950 carb, Jim Landis Headers.
It actually made 10 more HP with a "Vac Pump" on it. LOL!
The Video
IMG_1989.MOV by Rick Jones, on Flickr
The Parts car. They made a total of 921 Rambler American Convertibles in 1967. I have 3 to restore one out of.
IMG_4501 by Rick Jones, on Flickr
Old 04-05-2021, 09:04 AM
The way that dyno chart is charted makes that engine look peaky but it's got >500hp and >575ft/# at 4500RPM. Wow! That would be sooo fun to drive!
I notice the oil filter faces the front of the car. How is that? Do you know what car this engine is going in?
I have to be honest, I always get super stoked to see updates here but each time you post an update, I know your retirement is rolling closer and I am a little sad, too.
Old 04-05-2021, 10:10 AM
SC/397's Avatar
It is going in the Hornet race car that I showed on page 1. He has a remote oil filter system that he mounted in in front rather than on a fender well or some other place.
http://www.ifsja.org/forums/vb/showthread.php?t=189529
Peak Torque is 586 at about 4400 rpm.
Peak HP is 652 at about 6500 rpm.
This is the final pull to back up pull 21.
IMG_4519 by Rick Jones, on Flickr
Old 04-08-2021, 10:51 PM
crazydog's Avatar
crazydog crazydog is offline
Any idea when the torque curve hit 500+?
That is very impressive!!!
1979 Cherokee - Built 401, NV4500, Dana 300, 6" BJ's Lift w/ Bilstein 5125 Shocks, Goodyear Wrangler MT/R 35X12.5R15, Front Brake Upgrade w/ GM 2500 Calipers & EBC Pads, Rear Disc Brake Conversion, Z&M Jeeps Dash Insert w/ VDO Series 1 Gauges, Tad Rack, Ramsey Hidden Winch w/ REP8000, Hydroboost, CS140
1967 J3500 - Making plans
Old 04-09-2021, 02:34 PM
SC/397's Avatar
I really don't. Obviously with a race engine we were just trying to tune it and find where the peak horsepower was going to be. Honestly, we were hoping for it to peak closer to 7000 rpm and along with that a little more horsepower.
We used the Torker intake that he had but I wish we could have swapped it out for a Victor Jr. or a Indy intake. Fun stuff nonetheless.
Stalled projects hall of shame? babywag General Chit-Chat 21 11-18-2019 01:30 PM
Projects ownership do we own them or do they own us Quadruple bypass Introduce Yourself. 5 01-29-2019 08:33 PM
Too many projects. Anyone else have this problem? FSJ Guy General FSJ Discussion 44 11-15-2009 11:16 AM
Buick 455 vs Olds 455 vs Pontiac 455 krek General FSJ Tech 45 04-22-2008 11:49 AM
