Old 04-09-2011, 01:18 PM
jwalton23's Avatar
jwalton23 jwalton23 is offline
Installing 6" lift!
Just some random pics of my install. thought i would share!
this is what rustys off road sent me
this is with the rear on.
got the front on just gotta change the break lines and slap the shocks on and its ready for the road as soon as my sway bar disconnects get here from bj's. anyone running this lift have any problems that i should be aware of?
91 Grand Wagoneer
AMC 360 / Torqueflight 727 / NPM 229
Dana 44 front and rear
6" Rustys Offroad suspension lift
BJ's quick disconnects
BJ's PreRunner front bumper with winch plate
fenders trimmed
35x12.50x15's Maxxis Bighorn mudders
Rhino grill
http://www.tnjeeps.com/
Old 04-09-2011, 01:19 PM
jwalton23's Avatar
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-09-2011, 01:22 PM
JohnnyJ's Avatar
JohnnyJ JohnnyJ is offline
Looks good!
Past Project: Stock Class TREC Racer Build Thread
Current project: bringing back my 75 Wagoneer
Old 04-09-2011, 02:45 PM
Looks good! Nice lookin wag too. Too bad about the fenders being chopped, still looks good though.
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 04-09-2011, 05:23 PM
Topgun2mo Topgun2mo is offline
Great! I like your workspace!
Mike Morgan
Slidell, LA
'90 Grand Wagoneer
SOA, CUCV 14 bolt rear, 4.56 and Detroit, Looking for HP Dana 60 for front, 1" Body lift, 44044 Rancho Springs up front, Dodge 4x4 Rear leafs and shackles, BJs 1" lift shackles in front.
Old 04-09-2011, 05:47 PM
78 Wagoneer's Avatar
78 Wagoneer 78 Wagoneer is offline
Very nice!
Old 04-09-2011, 06:14 PM
FSJ Guy FSJ Guy is offline
X2. We're all jealous of your shop. When is the 4 post lift arriving?
Ethan Brady
www.bigscaryjeep.com
Old 04-09-2011, 06:36 PM
jwalton23's Avatar
i wish that was my personal shop! That's at my job. luckily i get to work on my own vehicles when we are slow at work. i work at a commercial tire shop changing tractor trailer tires all day. Thank you for all the compliments. I didn't want to chop the fenders but i wanted to fit 35's more so out came the sawz-all and grinder...lol.
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-11-2011, 05:29 PM
jwalton23's Avatar
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-11-2011, 05:34 PM
CutterN55's Avatar
You'd have to cut a little to be able to stuff 33's with a 6" anyway...don't feel bad. Mine's about get cut some more too. Good job on the cuts. I'm going for the same look. I've been dreamin about turning mine into a green de-wooded waggy and getting on 35's. I'm going to de-wood and keep the color though. It's grown on me. Nice truck.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 04-11-2011, 05:35 PM
jwalton23's Avatar
Finally finished. just waiting on my sway bar disconnects from Bj's. They should be here tomorrow!
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-11-2011, 05:42 PM
temps425's Avatar
temps425 temps425 is offline
Fun, that spring lift has to be the most rewarding job you can possibly do on a fsj. Super easy and once u put the big tires on, your like aowwwwwhhheeaahhhh
Old 04-11-2011, 05:43 PM
CutterN55's Avatar
how was that again?
Again, truck looks great!
ROMANS 12:1-2
'89 GW deceased
Old 04-11-2011, 05:50 PM
jwalton23's Avatar
I am not a fan of the green either...that was the PO choice of ugly. I plan on getting it in the garage soon and putting it back to the white that it was. I think white with black bumpers (pre runner front and a custom rear with spare carrier) will look real nice. But until then itll be ugly so i can off road with out worry...lol. Thanks for all the compliments!
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-12-2011, 06:50 PM
jwalton23's Avatar
ok i took my first road test today. got a little drive line vibration. i think i may have to loose the front springs and throw in some shims. anyone got any other advice? also my lower ball joint is loose. would that cause a vibration or just a clunking?
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-18-2011, 07:16 PM
jwalton23's Avatar
Okay I've done some research and am completely confused. Every where I read it says that I can run the 6" lift with the stock drive train. I have a vibration in the rear drive shaft. comes in at 55 and fades a little at 65. I am at a loss. i have checked all the u joints front and rear and they are all good. no play what so ever. they have all been grease as well as the entire front end. and it just came out of the alignment shop. any input would be appreciated.
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-18-2011, 07:54 PM
CutterN55's Avatar
maybe you threw a weight? Tire out of balance?
ROMANS 12:1-2
'89 GW deceased
Old 04-18-2011, 08:12 PM
J20 project's Avatar
It doesn't appear that the rear has a shim...should have one.....
J20
BP Drivetrain...........
775-537-7918
Old 04-18-2011, 08:19 PM
jwalton23's Avatar
the block for the rear is tapered at 5 degrees...or so says rustys offroad and all the tires still have all the weights.
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-18-2011, 08:39 PM
247pia's Avatar
247pia 247pia is offline
Speed sensitive is either tires or drive shaft. First and easiest thing to do is rotate the tires then road test.
Remember rear pinion angle should be the same as the rear transfer case out put angle with a single cardan style drive shaft. So if your transfer rear output is at 7* then you want you pinion at 7*.
79 Cherokee 360, T-18, Dana 20, Locked tons. I give up.
08 Liberty, 97 Z71
Another 6" Lift Question...Hellcreek?RUSTYS?? draglink Off-Road FSJ Tech 10 01-31-2009 12:25 PM
BJ's 6" lift for grand Wagoneer 4x4marine General FSJ Tech 22 10-13-2008 09:32 PM
People with a 4" or 6" lift please read. BassnTruck General FSJ Tech 26 05-06-2007 12:26 AM
Waggies with BJ's 6" Lift Question PhilG General FSJ Discussion 5 04-24-2007 08:42 PM
Using 1/2 of RB's flip to make up for block in rear of 6" rusty's lift bearfacedkiller Off-Road FSJ Tech 3 02-06-2004 12:53 PM
