Old 08-18-2009, 04:41 AM
wickedwagon767's Avatar
wickedwagon767 wickedwagon767 is offline
Lightbulb 4" lift Chevy springs up front
I have a pair of new TCI 4" EZ Ride front springs that I bought for a Suburban and I'm thinking about using them on my cherokee spring-under at 1st then spring-over later. Anybody done this?
Any idea how much lift these will give me spring-under? The arch seems to match an FSJ 2" lift spring......
Old 08-18-2009, 10:37 AM
Gearhead 1990's Avatar
Gearhead 1990 Gearhead 1990 is offline
Should be about 1-2'' lift spring under. It will also move your front axle forward ~1-1.5''
No jeeps at the moment
Old 08-18-2009, 01:24 PM
Know if the spring eyes will bolt into the stock frame/shackle mounts?
Old 08-19-2009, 11:17 PM
You will have to either get different bushings or be able to use a sawzall pretty well
Old 08-20-2009, 01:55 AM
The springs were shipped with poly bushing from TCI. Eh, I have a set of Rough Country FSJ 3" springs as an option too.
Old 08-20-2009, 02:13 AM
Stumblinman's Avatar
Stumblinman Stumblinman is offline
I started to use the front Chevys and had to hack up the bushings to fit. They were 4" lift but didn't look much different from the stocks. I ended up using Chevy rear springs and their bushings went in fine but then again that's a different story.
It's not the leaks that bother me, it's when they stop that makes me worried.
1988 Waggy SOA stretched, cut, Chevy R. 4" springs in front, shackle reversed, stock springs reversed in back, Edelbrock manifold and carb, mini-spooled front, lunchbox rear, currently on spaced 35s.
www.FairbanksOffroadLions.com
Old 08-20-2009, 10:30 AM
Desert Rat Desert Rat is offline
I'm running a set of 2.5" Rancho Chev springs in an SOA configuration on my Xterra. The X is heavier than your wag and they're almost unbearably stiff. When the weather cools I'm going to pull a leaf out of these packs and see if that helps.
www.nissan4wheelers.com - we're the guys using up all the spare driver drop waggy axles!
Old 08-20-2009, 05:51 PM
Also I was thinking there are 1/2 ton and 3/4 ton springs. It's a long shot and I'm just guessing but... maybe they have different stiffness factors involved.
