Old 11-01-2008, 02:34 PM
i recall i said i was done messin' with this junk,so why's all this on the bench?
.030 over 360 block,decked. late one with 5.9 cast in the side.
rebuilt heads.bowls cut for the AMX/SS oversize stainless valves. 2.08in 1.74ex.
wiseco pistons. 9.25 cr,custom compression height w/1" pins.
crank fresh from the shop. sharp eye will see it was balanced.
clevite bearings,of course.
8601 cam for strong mid-range,,Rhoads lifters to restore the low end punch
early 3310 carb. 4 downleg boosters,4150 with 2 powervalves. 780cfm
727 ready to go,waiting on the 5600rpm governor to be installed.
Old 11-01-2008, 02:39 PM
mattmopar440's Avatar
AWWW CRAP there goes the neighborhood
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 11-01-2008, 02:51 PM
Gambler68's Avatar
Rabble Rouser
if that doesnt make a grown man squeal like a little girl, I don't know what will.
Nice!
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 11-01-2008, 02:53 PM
Nice!
lol,yeah.
did i mention that's a 401 crank/rods going in the block?
Old 11-01-2008, 03:18 PM
scantar's Avatar
scantar scantar is offline
...umm...wow!
Old 11-01-2008, 03:28 PM
shadowjeep's Avatar
DROOL, soooo when are you going to put that pile together?
Rick C.
www.kymc.org
shadowjeep
2003 Chevy Silverado
Old 11-01-2008, 03:29 PM
Gambler68's Avatar
Rabble Rouser
Nice..so it'll be..a 384+the bore?
I need to get crackin on my 401..I almost hoped the 327 would 'break' so I'd have a reason..alas the old 'mid' block resisted my futile efforts at hurting it.
So I guess the big question is..what's that gana go in?
Old 11-01-2008, 03:46 PM
it'll be a 391ci.
going in the '91 GW i picked up for the new daily driver.
assembly begins a couple hours ago,will be in the truck in a couple weeks.
getting headers with dual exhaust. dynomax super turbos'.
Old 11-01-2008, 03:49 PM
it'll be a 391ci.
What type of headers?????
87' Grand Wagoneer
Inferior Chevy
Old 11-01-2008, 03:50 PM
hedman. that block is the original from your GW.
Old 11-01-2008, 03:54 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
Way too cool! so how does the balanced crank work with the flexplate? Or did they balance the whole rotating assembly?
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
COLOFIREMAN's Avatar
Gone,But not Forgotten.
Why oh Why did I sell my 401
Ohhhh that's right we're having a baby.... .....I guess that's a fair trade. JK JK
Old 11-01-2008, 04:05 PM
Sweet mother of pearl!!!
Old 11-01-2008, 04:08 PM
hedmans. that block is the original from your GW.
Hedmans common mike
SO your stealing parts from my own truck to beat me I see how this is going
87' Grand Wagoneer
Inferior Chevy
Old 11-01-2008, 04:13 PM
the whole rotating assembly was balanced. flexplate to harmonic balancer. i have the balance job print out,i should scan it in.
yah,hedmans are crappy. so are the rest,so why spend 3 times more. i dislike headers,but figured i shoukld use them on this one. i've used hedman before and got them to seal.
Old 11-01-2008, 04:16 PM
What type did you put on jon's chero ?????
87' Grand Wagoneer
Inferior Chevy
Old 11-01-2008, 04:17 PM
Gambler68's Avatar
Rabble Rouser
Come on, have a hot set of thick flange high flow headers built for that beast!
Old 11-01-2008, 04:21 PM
Yea mike my Edelbrocks looks sweet and flow great
87' Grand Wagoneer
Inferior Chevy
Old 11-01-2008, 05:02 PM
frank_c frank_c is offline
my friend works for Wiseco and says thanks for buying 'em!
83 Waggy
87 J20
99 TJ
05 Crossfire SRT-6
Old 11-01-2008, 06:01 PM
Old drag racers trick on common flange headers, cut them between the flanges this will allow them to tighten up. Of course you could add metal to them then take a mill and mill them off square too.
