  #41
Old 05-11-2007, 07:10 PM
Kimbrough's Avatar
Kimbrough Kimbrough is offline
Anybody attaching the draglink to the passenger-side steering arm next to the tie-rod? Anything wrong with that setup?
1991 Hunter Green Grand Wagoneer. Chevy 350 TBI. 4-inch lift. 31-inch BFG AT's.
Old 05-13-2007, 08:14 PM
malodin's Avatar
malodin malodin is offline
dont know yet, i think the only major thing would be length might be a little short(suppose it mainly depends upon your lift vs highsteer arms
Old 05-14-2007, 09:05 AM
salamander's Avatar
salamander salamander is offline
ok i relise that a highster system would be best. However on scouts and samuris in the old days we used Z link. Wich dose have down sides bump stere you half to build it. I have run this it dose work for a while and alow you to use your rig while you save up for high stere. Just a thought.
yes this is old school
yes it was the only way back in the day
yes there are better ways now
but it works
PS my POS will have one to get it going till i collect all my high stere parts
1986 J10 258 4SPD 35S NEEDING MORE GOODIES
1989 toy x-cab lockers 37 mtr 5.29s cam
1990 toy 4.3 v6 38 boggers sand toy
Old 05-14-2007, 09:17 AM
Not me personally but there are a few pic's like that in the BillaVista steering research pages over on Pirate.
As long as nothing binds and turning effort/radius remain about the same i'm thinking it's not a big deal.
Old 05-14-2007, 05:02 PM
Doug3651 Doug3651 is offline
I've been doing a lot of research on the SOA lift and I think I have all the items covered, but then I came across this exerpt from the CFSJA.org lift kit artical.
Then, to correct caster, which enables you to steer properly and causes the
wheels to recenter after turns,
the steering knuckles must be cut off and
re-welded at the proper angle.
This isn't something for a shadetree mechanic
to try. Only a very skilled individual who won't weaken the axles and will
set up the driveline angle properly can pull this off. I'd expect to pay at
least $1000 for this job. You might also need to look at high clearance
steering kits to avoid hanging up your tie rods on every rock. This isn't a
DIY as a mistake can, of course, be deadly. You'll need a mechanical engineer
for the design and a machinist for the implementation to do this right.
That's why it'd be better to buy a kit. There, you've been warned
This is the first I have heard of this?? Can I get a bit of input on this from you SOA guru's?
Thanks!
Old 05-14-2007, 08:36 PM
Originally Posted by Doug3651
...Can I get a bit of input on this from you SOA guru's?
Thanks!
Yes, you can.
It's wrong as far as it applies to our FSJ's as long as you mount the SOA perches in the same orientation to the original perches.
I'm not tooting my stuff here, but unless you rotate the pinion up, you did not change anything. Nothing, Nada, No Place, No How.
With all due respect, I have asked several times to have that portion of the CFSJA writeup edited for accuracy, that portion is just BS.
I doubt the author has ever performed an SOA himself or drives a SOA FSJ rig.
I drive one (a SOA FSJ rig) almost daily, I drive one on the interstate at 65-75 mph, some times for 200 miles at a shot.
(yes, I know who the author is, he's a mod here and a good friend of friends of mine, but I still think it's a bunch of second hand compiled bull ****).
Old 05-15-2007, 05:50 AM
Kimbrough's Avatar
Thanks!
They don't call it the Off-Road FSJ Tech forum for nothing.
Old 05-15-2007, 08:43 AM
Thanks Tad!
I was gettin a bit worried about doin my SOA. You have revitalized my motivation!!!
Old 05-17-2007, 04:09 PM
Kimbrough's Avatar
drag link in front of tie rod???
I have a stupid question: Is the drag link supposed to mounted in front of the tie rod? If I try to mount on the rear hole, it crosses the tie rod. Sooo; DRAG LINK connects to forward hole on pass-side - TIE ROD connects to the rearward hole on pass-side. TIE ROD connects to where on driver's-side? Forward or rear hole???
Old 05-17-2007, 04:24 PM
j20brett's Avatar
j20brett j20brett is offline
tierod connects to rear hole, draglink to front.
Edit: there should be only one hole on drivers side. But if you do have 2, then the rear hole.
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 05-30-2007, 10:22 AM
Jeep4myBoys's Avatar
Jeep4myBoys Jeep4myBoys is offline
Alrighty - this thread is very good - really makes me more confident in being able to do this myself. I was thinking BJs 6" for the ease of installation, but I believe the extra flex from the SOA would be better.
Doesn't look like there's one complete write-up, but all of the information is here. Since I don't have time to pick everything up piece by piece or fabricate parts myself (I just went from working solo to taking over a company with 12 employees ) I would prefer buying in kits.
So, of course I'm thinking Tads SOA kit and learning to weld (I'll practice lots first, but any concern with a noob welding on an axle?)
For the high steer, I was thinking this kit from Parts Mike. Would that work in our application? I would probably use the super arm kit.
Parts Mike also has a TRE kit, would the tie rod still need to be shortened though?
I know this ends up being more expensive, but right now I just don't have the time to do more myself, and I would rather spend the time I have working on the jeep.
Also - since this would end up being much more expensive than the 6" lift, is the extra flex really worth it?
Thanks guys, this thread is very informative!
Timothy
It's for my twin boys Sure, they're only 1 year old, but it's all for them!
Daily Driver: 04 F350 6.0 CC LB FX4 Lariat
Jeep: 88 GW 360/727/229, Rusty's 4", 33" tires, Holley TA, TFI **Razor**
Old 05-30-2007, 10:35 AM
j20brett's Avatar
I was considering using the same kit form partsmike at first, but i just couldnt see putting that much money since i would be eventually swapping in a d60.
All you need is the pass. side flat top knuckle and one super arm. So this saves you ~$500. Its not highsteer but you dont have to have highsteer. But the tierod end kit would be nice to have.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 05-30-2007, 11:12 AM
Timothy,
If you do x-over you will keep your tie rod (you could have a new one made but if yours is in good shape it's not really necessary) intact/same location and just need a slightly longer drag link to connect to the passenger side high-steer arm (get one of the many taller/super arms or get one with the spacer) on a flat top knuckle that has been milled/tapped/with the proper studs/cone washers and nuts, along with a 4" drop pitman arm.
I'm pretty sure both Parts Mike, Bull Gear and more than 1/2 those vendors listed on the first page will fab one up speedy like or sell you the whole package.
Old 05-31-2007, 07:25 AM
I've looked, but I don't see a good overview of the crossover steering. From what I'm gathering, you basically use a driver's high steer with the drag link under the springs? I'm not sure I get it, and I haven't seen one in person.
Anyone have a good,summary of what the crossover steering setup is?
Timothy
Old 05-31-2007, 07:47 AM
j20brett's Avatar
You dont need the drivers side if you are just doing crossover steering. Only the passenger side flat top knuckle.
here is a pic...top is stock steering. bottom is crossover
Edit here is a better pic and a page with a good writeup.
http://www.pirate4x4.com/tech/billav...ngresearch.htm
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 05-31-2007, 07:53 AM
Thanks, that makes sense.
Timothy
Old 05-31-2007, 08:02 AM
I have a better pic of the completed assembly someplace.
Old 05-31-2007, 06:18 PM
malodin's Avatar
does your spacer on that picture have a taper to it?
Old 05-31-2007, 08:34 PM
It does have a taper, but that is not my spacer, arm or knuckle.
That's from a SOA welding road trip up to PHX I did back in March for a member here, SteelPonyCowboy.
IIRC he got the knuckle, spacer and arm from Kozz.
Here's a better pic of cross-over steering from JoshD in PHX.
Here's full high-steering.
Old 05-31-2007, 09:17 PM
malodin's Avatar
cool, i get the material this weekend to cut my own arms now, i am using 2 3/4 wide by a minimum of 1 3/4 thick by 9 1/2" long piece for one arm(then there is no need for spacers) similar to http://www.ottindustries.com/Steering_arms_dana44.html
these ones he he he
