Old 12-30-2006, 11:45 PM
malodin's Avatar
malodin malodin is offline
lol, crazy, that just confused me a little more, any chance you have some pictures of the different links your talking about? i think what your saying is, the dpa connects to the passenger side "flat top"(which is on my jeep but not my chevy 44) and then use the stock chevy arm going from both fronts of the nuckles? what is needed to mill the top of the arm? ive got a machine lathe and a 3way axis mill at work(if i knew what to do i could do it at work).
Old 12-31-2006, 12:03 AM
Crazy_Jeepman's Avatar
Sloppy Shifter
LOL I knew I was going to confuse that all up! LOL
Here is a pic of what I am talking about on the front of a Chevy
http://www.shakerbuilt.com/parts.html
Old 12-31-2006, 12:07 AM
malodin's Avatar
would i be able to use the jeeps stock rod(cross over part) or would i have to get a new rod as well to go from the dpa to the nuckle
Old 12-31-2006, 12:11 AM
Sloppy Shifter
Nope you would need a custom drag link (From Pitman Arm to new steering arm location) However you will be able to use the Chevy stock center link (wheel to wheel link)
Old 12-31-2006, 01:47 AM
malodin's Avatar
ok that makes sense, so no matter what im gonna have to speen at least 150 to get it going, any threads or any info you have on making a drag link? i.e. what i would need to do it? ive got all the tools i think to create the draglink mill the flat top nuckles etc.
also whats up with the 10degree correction thing?
Old 12-31-2006, 12:35 PM
lifenajeep's Avatar
lifenajeep lifenajeep is offline
Man, I just built two systems the other day for this exact set-up. I am shipping one out on Tuesday but I will get some shots of the other before and after it gets installed. I am using 1.5"x.250 DOM with 7/8" hiems rated at 50000lbs. The kits are going on a CJ and a YJ that have converted to FSJ NT D44s but are still using the stock spring mounts on the axle. There will be a draglink length difference but that's about it. These are not a high steer set-up but do increase the strength of the steering considerabley. Pictures, I know. soon come
Phillip S. Losh
SEARCHERS 4WD Supply and Outfitters http://www.Searchers4wd.com
225-744-4947
I have a Jeep....or two
Old 12-31-2006, 12:51 PM
malodin's Avatar
lifenajeep, that would be cool i would love to see some pictures.
Old 01-08-2007, 05:45 PM
AlsChopShop's Avatar
can we get some breakdowns on crossover steering solutions?
i'm back in the SOA game and i don't have that kind of cash for full hi-steer, i'll settle for x-over.
what are the cost break downs on just going crossover? just trying to get a parts list going as i start scrounging for cheap parts.
Al
Old 01-16-2007, 04:17 PM
Twozerofour Twozerofour is offline
Is it possible to run a soa, with out a cross over or high steer. or are there clearnce issues with the leaves and steering links. I am aware of bump steer issues ect. with ghetto steering set ups. 81waggy.
Old 01-17-2007, 09:40 PM
malodin's Avatar
twozerofour, i believe it is possible only to say move it out of the garage and around the corner, but definately not safe or plausible to drive on the road, as the angles the arms would be at would be so great that either you would have no turning radius or it would be extrememely squirly and quick steering(dont quote me on that though as i have not done my soa yet)
Old 01-18-2007, 01:37 AM
from what i've read, even with a 6" DPA the drag link will hit the spring on right turns.
Al
Old 01-18-2007, 09:16 AM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
You will hit the spring. However, I did run mine for quite a while with only a 4" DPA. It still hit the spring, but it worked. I did not even have that bad bumpsteer. I would just save up for the high steer if I were you though
Old 03-01-2007, 04:42 PM
rockingon24_7's Avatar
rockingon24_7 rockingon24_7 is offline
my 74 j-10 is sitting on axles from a 88 dodge ram (dana 44s) with a crossover steering that cost me under $50
STEERING ARM---first i took a 1x2 bar stock and notched it (you can see in the picture) then I drilled the 3 bolt holes the size of the tap hole then I clamped the arm to the knuckle and drilled the holes on through. Unclamped the arm tapped out the holes in the knuckle by hand (I think it was a 9/16-18 tap) then i drilled out the holes bigger in the arm to 9/16 so the bolts would fit through. Next i made the 1inch spacer out of another piece of stock and notched/drilled it to match.
DRAGLINK---the drag link is a modified stock draglink from my j-10. From the adjuster to the steering box is stock. I got another drag from the junkyard and cut the threads off and had it machined to have the threads go in the oppisite direction(so it could screw into the adjuster where the end used to go)Then but welded a tractor 3pt hitch hiem joint to it and then sleeved that and bolted it in place.
I THINK thats all I did and it seems to work fine but maybe I got lucky. There has not been any slack in the joints nor bolts that backed off.
1950 F1, V8-thm700 previous dd, Suzuki Bandit 600,
Dodge Dakota, it's a gray grilled white work truck kind of truck, dd
74 J-10, was the farm truck until I started rebuilding it
360/727/np241, Holley TA, SOA/SF, 106" WB, dana44s lockers, 35"mt's, winch and still much more to come.
Old 03-05-2007, 09:13 PM
LaJ10's Avatar
LaJ10 LaJ10 is offline
I thought I saw somewhere a diagram of what needs to be milled drilled and taped on a pass. side knuckle somewhere but cant find it anywhere now has anyone else seen it?
1983 J10 258\NP435\NP205\Chevy TBI \comp cams cam\4.0 head\Clifford intake\Centerforce clutch\4.56's and 35x12.50x16's\14 bolt rear\welded at both ends\with astro van hydroboost\SOA front with partial 4"lift springs,rear springs inboarded with shackle inversion
Old 03-05-2007, 09:42 PM
malodin's Avatar
http://web.acsalaska.net/~cvandor/wilhelm/flattop.html
try this page, hes very open and answers questions. best page ive found so far.
Old 03-06-2007, 12:50 PM
LaJ10's Avatar
That got me where iwas trying to go.Thanks
Old 04-25-2007, 08:57 PM
malodin's Avatar
id like to keep this going, see some more pictures of peoples steering setup, im in the process of milling/drilling/tapping my nuckles(and yes i will be able to do it on a regular basis for people here in a few months) and then i will be making some highsteer arms and would like to know more info.
Old 04-29-2007, 08:35 PM
Jim Blair's Avatar
Jim Blair Jim Blair is offline
Rig and Axle Type: '84 J10 with Ford D44 front
Type and Vendor: High steer arms from Ott Industries in British Columbia, Canada (originally I used Off Road Design arms, but they allowed the tierods to hit the leafs)
Parts Used: Stock tierods and ceneterlink from the Ford and draglink from the J10
Price: Bought in '02 and not sure how much anymore
Procedure: If you run a Chev or Dodge axle from the '70s, toss the boomerang from the LH knuckle (and duck!) then have the other knuckle planed and drilled mirror image (if it's flat top) The arms bolt directly to the knuckles and the Ford centerlink bolted to the arms. The J10 draglink bolted to the centerlink with the stock Jeep RH tierod.
I have http://ottindustries.com arms on my drilled J20 flat tops (on a Ford D44 open knuckle front axle from a '76 F350 highboy crewcab so I have LH drop front axle and it bolted directly in) with all (otherwise) stock steering components. The Swaybar plates became my shock mounts and with new Ubolts, the nuts face upwards, so no dragging (doing the same to my '73 J4000 with a '76 J20 front axle swapped in when I get time)
I put new centering studs in, but I could have just rounded off the old one's nut and shortened the threads to fit in the centering holes.
The brakelines are extended ones for a '77 Blazer K20 and brakes (knuckles and calipers) are from a '76 J20.
My truck recently (with 4.0L under the hood)
OTT arms
Spring bolts inverted
Side view of OTT arms showing clearance from springs
Old 04-30-2007, 06:05 PM
malodin's Avatar
Jim, thanks thats helfpull as well, im working on building my own arms out of 1 3/4"x1 3/4 solid (something steel i imagine) and doing a step up similar to the ott design.
Old 05-09-2007, 09:51 PM
malodin's Avatar
here it is, my first milled drilled tapped knuckles ready to bolt onto my friends rig, pretty soon i will be making my own arms as well(these are koz offroad arms)
this last pic shows the difference between the factory gm 26.5 cone washer and koz offroad cone washer(which is just a tacoma screw product, or used to be it is now discontinued)
personally i dont see the need for the bigger conewasher the way these are bolted down and all, unless maybe someone is running 44's with hydraulic ram steering etc.... this first set of knuckles is going on a f250 with 39 irocks so we will see how they do.
once i get my reamer(either gm taper 26.5 or the tac screw conical washer taper) i will be making steering arms.
