Old 12-31-2002, 06:33 PM
netbear netbear is offline
Question
Hi Folks,
I bought a set of axles from a 1978 J20 3/4 ton
truck to use in my '79 WT Cherokee. My question
is in regards to the front D44 from the J20.
Where manual locking hubs would be, there are
silver caps sealing the end of the hubs. I assume
this was because the J20 donor truck had an automatic trans with Q-Trac. How do I remove these
silver "caps" and will manual (Warn) hubs for a
D44 bolt in? What are these things called?
Regards,
netbear
netbear
Old 12-31-2002, 06:41 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Pry the caps off with a screw driver, remove the continuous hub components, install the manual hubs, of your choice.
Old 12-31-2002, 07:26 PM
Thanks for the info!
netbear
Old 12-31-2002, 07:40 PM
J20 project's Avatar
Whoa, silver caps on a J20 axle, 78? My 76 had drive flanges on it from the factory. Does this have a 8 hole pattern or a 6 hole wheel pattern? I thought the silver caps were only on the 6 hole J10 w/ qtrack. At any rate, yes they will pry off and hubs will install but if they are 8 hole hubs they take a different lockout hub than the silver capped 6 hole hub. J20
BP Drivetrain...........
775-537-7918
Old 12-31-2002, 07:57 PM
The front Dana 44 axle from the J20 is eight lug, big disk brakes, etc.
Any idea which Warn hubs I sould get and will
I need any other parts? (Rear axle from the J20
is a Dana 60, eight lug, big drum brakes.)
netbear
Old 12-31-2002, 11:23 PM
fourtrax fourtrax is offline
All the Dana 44 lockouts are the same weather they are 6 or 8 lug! I just put J20 axles under mine and the lockouts that were on the six lug bolted up to the 8 lug.
89 Grand Wagoneer 4\"BDS lift, Bushwacker XJ flares, 33x12.50-15 Goodyear MTR\'s, 401/727/229, D44HD/D60-3, 3.73 gears<br /><a href=\"http://www.quadshopatv.com\" target=\"_blank\">www.quadshopatv.com</a>
Old 01-01-2003, 12:17 AM
Sloppy Shifter
No it takes the same hub, it uses the same guts as the 6 hole axles.
Old 01-01-2003, 05:28 AM
CowKiller CowKiller is offline
FSJ Executioner
save then continous hubs though! i carry one with just incase i blow apart a hub, can take out the hub peices and insert this and away ya go.
Corey Zakeosian
2002 gmc 2500Hd duramax
2000 Ford f-550 work truck
1986 f350 6.9 diesel hp60 front, sterling 10.25 rear, 36x12.5 military wranglers. TOY!
NO JEEP
I am ready to meet my Maker. Wether my Maker is prepared for the great ordeal of meeting me is another matter
Old 01-01-2003, 01:19 PM
Ok, Someone explain to me why my dana 44hd on the front of my 76 J20 had drive flanges instead of silver caps. Also explain why it has 19 spline outer axles and regular chevy/dana 44 hubs/jeep style also, don't fit it? Not being a smart@#, but someone please explain the difference.
J20
775-537-7918
